Alloy welding question.
- Has thanked: 9901 times
- Been thanked: 10212 times
To weld an alloy frame part on a bike,does the battery need to be disconnected?
- Has thanked: 541 times
- Been thanked: 7594 times
Re: Alloy welding question.
To weld ANY part on a car or motorcycle you need to disconnect the battery, IMHO.
I had a professional weld an alloy mount point on a Ducati engine. He insisted I removed any parts that were sensitive to heat as the whole thing needed to be pretty hot to do a good weld.
It's a bobbin mount commonly seen on the bottom of a swinging arm,so it would be a bit away from melty bits
- Has thanked: 10336 times
- Been thanked: 6915 times
- Has thanked: 1361 times
- Been thanked: 1749 times
Gas welding can harm via the heat being too close.
Lecky welding (TIG, MIG, MMA) can damage sensitive electronics so its better you disconnect that stuff if you can. Also it can damage things via the heat.
Or in other words, how much does yer ECU cost to replace?
Please sir, he copied my answer.demographic wrote: ↑Fri Oct 21, 2022 11:08 pm Gas welding can harm via the heat being too close.
- Has thanked: 6413 times
- Been thanked: 4797 times
IIRC some bloke completely fritzed the ABS on one of the LWR bikes when he leccy welded a frame part without disconnecting anything.demographic wrote: ↑Fri Oct 21, 2022 11:08 pm Gas welding can harm via the heat being too close.
Good info,thanks folks.
- Has thanked: 65 times
- Been thanked: 1235 times
If you weld a gs1150 subframe without removing the battery, you fry the abs unit, just ask Charlie or Euan!
