Cooking with science!
Re: Cooking with science!
I always do poached eggs in clingfilm - line a little bowl / ramakin (sic) with clingfilm and crack the egg into that, then twist the top so you've got a little eggy bag. Then poach as normal. AFAIK that's how they do it in restaurants, it means you can poach them all in advance to within 30s of done and store them in ice water, when you want one to serve you just chuck the package in boiling water for 30s and job's a goodun.
Interesting on the bacon - it makes sense to me though. The water keeps it at 100°C during most of the cooking (the same concept is used in various kinds of evaporative coolers) and then you only get the really high temperatures right at the end. Gentle cooking 'through' and then a bit of colour to get the maillard reaction on the outside.
It'd probably be really good on some properly thick bits of bacon
I get mine from a butcher now, he slices it off there and then for you. Bacon steaks
- Has thanked: 2557 times
- Been thanked: 4167 times
Completely agree on the 'boil your bacon in water' thing. It's the best way I've found to cook bacon. You get bacon that is magically soft and also crispy, without turning into bacon flavoured cardboard.
I also watched a guy cooking fried eggs in bulk a few years ago, and he basically cracked eggs into about an inch depth of vegetable oil at the right heat (i.e. not too hot). No dicking about flicking oil over the egg to equalise the cooking operation, just wait until the eggs are 'au point' then hoick them out with a slotted spoon.
- Has thanked: 779 times
- Been thanked: 3222 times
It's a new one on me, I shall have the wife give it a go over the weekendScrewdriver wrote: Wed Oct 19, 2022 10:29 am Ok so apologies for anyone who has discovered this trick with the bacon in particular...
- Mr Moofo
- Has thanked: 1926 times
- Been thanked: 1728 times
- Trinity765
- Has thanked: 3140 times
- Been thanked: 3188 times
I saw the acid egg thing on Youtube. What put me off is you have to soak them for 10 minutes - leave them too long they pick up the acid taste (vinegar in the vid), not long enough and it doesn't work. I use the oiled sandwich bag method for poached eggs which is pretty full proof. The semi-poached bacon thing is interesting though so will try that. Looks good!
- Mr Moofo
Cooking with acid ( be aware it’s not cooking as such - but denaturing of the protein) has been used traditionally - probably the best known be Ceviche or the Hawaiian version Poke.
It is why , when’s you marinade fish, you shouldn’t put the lemon on until the last minute.
As for the bacon thing - I will try. From a good science perspective, fat begins to render at 73 degrees - so rendering will occur in both water and straight grilling. I am guessing the water will bind in the protein. But also dilute the flavour?
Heston Blumenthal advocates cracking them into a sieve I believe, to get rid of said watery layer.
It's 50/50 to me which is more hassle - doing 'em in clingfilm, or pre-poaching (pickling?) them.
- Has thanked: 316 times
- Been thanked: 1078 times
Tried the bacon this morning, can’t say I noticed a huge difference but I’ll try it again at some point.
In terms of poaching eggs, the following is the ‘best’ way of achieving a perfect soft centred egg:
Large pan, lots of gently boiling water with a generous amount of vinegar in it (I use white or malt, what ever is to hand)
Crack a large fresh egg in to a ramekin - if the egg isn’t so fresh, use Heston / Nigella’s tip of straining off the surplus liquid
Shout at Alexa to set a 3 min timer *
Tip egg(s) into boiling water
After three mins, remove pan from heat
Lift out eggs with slotted spoon and tip onto tea towel to remove excess water
Serve
*If cooking to serve later, 2.5 min timer, lift out and pop into lots of iced water, reheat in simmering water for 30 secs
Serve
- Mr Moofo
I have never found a way of stopping poached eggs from tasting of vinegar - so stopped using it.
Tried the cling wrap route but that just leads to the egg sticking to the cling wrap!
- Has thanked: 8046 times
- Been thanked: 5697 times
Fascinating stuff. I always thought that the egg white solidified through cross-linking ie polymerisation sort of thing. Never knew that denaturation was actually breaking the weaker bonds. Apparently you can do the egg trick in acetone.
(It's implied that sodium bicarb will work too).
My missus will judge a hotel kitchen based on their poached eggs. Any hint of vinegar and they're immediately ranked as 0 Star. There's a café above what was the Army and Navy (now House of Fraser?) in Guildford (great views) that churn out 100s of eggs benedict every day and always spot on. They must pre-prep batch loads and I'll bet, after reading this thread, they use a cold process.
- Been thanked: 2730 times
Methanol has the right boiling point for cooking eggs perfectly, 65 centigrade.
Why not just use silicone egg poachers? Smear a bit of oil or butter on the inside, pop the egg in and boil for 4-5 minutes. No need to over-complicate it.
https://www.ebay.co.uk/itm/193881725460
- Mr Moofo
That actually produces coddled eggs not poached ones.mangocrazy wrote: Thu Oct 20, 2022 11:16 am Why not just use silicone egg poachers? Smear a bit of oil or butter on the inside, pop the egg in and boil for 4-5 minutes. No need to over-complicate it.
They are okay - but closer to boiled than poached.
It's a simple thing to cook - but there does seem to be an art to getting it right.
In the food industry everyone got really moist about sous vide cooking a few years ago - 50 degrees for a few hours. Never quite understood the obsession.
Re the comment on the air fryer - I made it because it seems to be the go to answer at the moment. You can boil and egg in an air fryer - but it will be too "drying" to poach anything.
The molecular cuisine ala Heston may well have had its day. Sometimes it can taste really good - other times it is just really seriously fucked about food for the sake of fucking food about. Highfaluting chefs love it - cos it makes them rock stars.
That said there are obviously things that can be learned.
Its a shame that more cheffing is not just using local ingredients really well. I have never seen anywhere around here offering the scallops that they catch around here! They all go to Korea
I still refuse to call my air frier an air frier, it's a tiny oven! Saves me loads on leccy though and it was free, so I begrudgingly like it.
I've looked at those silicone things too. They don't make poached eggs, that's my main criticism
I went all out and got a Ninja Multi function oven - https://ninjakitchen.co.uk/product/ninj ... zidDT200UKMr. Dazzle wrote: Thu Oct 20, 2022 11:41 am I still refuse to call my air frier an air frier, it's a tiny oven! Saves me loads on leccy though and it was free, so I begrudgingly like it.
I've looked at those silicone things too. They don't make poached eggs, that's my main criticism![]()
A bit spendy but a council house tea* can be on the table in 15 mins from cold versus 45 mins (including preheat) with the main oven. It gets used most days due to speed and lower energy usage.
I chose the oven over the machine version as I knew I’d be able to use it for all sorts rather than just cooking oven chips (which it does exceptionally well
We have also started batch cooking and freezing meals as well, makes a big difference in terms of sitting down for dinner after work and surely / Shirley, it must use less energy overall when compared to cooking two dishes from scratch…
*bacon, sausage, egg, chips and beans.
- Has thanked: 781 times
- Been thanked: 1072 times
Aren't the silicone things the same as wrapping them in clingfilm? Heat without touching water.Mr. Dazzle wrote: Thu Oct 20, 2022 11:41 am I still refuse to call my air frier an air frier, it's a tiny oven! Saves me loads on leccy though and it was free, so I begrudgingly like it.
- Mr Moofo
Not really - in the silicon they get cooked by steam.Mussels wrote: Thu Oct 20, 2022 1:23 pmAren't the silicone things the same as wrapping them in clingfilm? Heat without touching water.Mr. Dazzle wrote: Thu Oct 20, 2022 11:41 am I still refuse to call my air frier an air frier, it's a tiny oven! Saves me loads on leccy though and it was free, so I begrudgingly like it.
