Possibly A Stupid Question
- Has thanked: 485 times
- Been thanked: 1430 times
In my camperbus there is only two seats when driving. Driver and the wifes seat. As it was a bus we just used seat out the back for her as it had an integrated seat belt but she is finding it uncomfortable and it does not adjust. I could easily make a seat base and use a car seat but i have nowhere to mount a seat belt. The frame holding the sides and roof on is all alloy and her seat is right next to a support upright beam, So Possibly Stupid Question time. Can i use 3cm box alloy as a belt support? Unsure if its strong enough.
- Has thanked: 261 times
- Been thanked: 1266 times
- Has thanked: 1264 times
- Been thanked: 1188 times
Re: Possibly A Stupid Question
They wont see it TBH as its behind trim what is between two windows. Only other option is lap belt or the type you see in rally cars wth the middle clasp what both options she hates. The floor is wooden so even a integrated belt is not ideal. The seat had four floor mount bolts but only two go through a chassis mounted spreader plate.
- Has thanked: 839 times
- Been thanked: 1242 times
That sounds like it will act like a hinge in an accident so any side mount is probably a good idea.Felix wrote: ↑Sat Oct 01, 2022 10:27 pmThey wont see it TBH as its behind trim what is between two windows. Only other option is lap belt or the type you see in rally cars wth the middle clasp what both options she hates. The floor is wooden so even a integrated belt is not ideal. The seat had four floor mount bolts but only two go through a chassis mounted spreader plate.
Its the rear two but the wooden floor is the main reason i want a better belt option. The belt clasp will be floor mounted rather than seat as that can easily be fixed through the main Chassis rail. The over the shoulder side mount is what is worrying me. My local MOT Garage owner is its MOT man and lives in the next street. Ill see what he says about the alloy when i next see him.Mussels wrote: ↑Sat Oct 01, 2022 10:37 pmThat sounds like it will act like a hinge in an accident so any side mount is probably a good idea.Felix wrote: ↑Sat Oct 01, 2022 10:27 pmThey wont see it TBH as its behind trim what is between two windows. Only other option is lap belt or the type you see in rally cars wth the middle clasp what both options she hates. The floor is wooden so even a integrated belt is not ideal. The seat had four floor mount bolts but only two go through a chassis mounted spreader plate.
Felix wrote: ↑Sat Oct 01, 2022 10:56 pmIts the rear two but the wooden floor is the main reason i want a better belt option. The belt clasp will be floor mounted rather than seat as that can easily be fixed through the main Chassis rail. The over the shoulder side mount is what is worrying me. My local MOT Garage owner is its MOT man and lives in the next street. Ill see what he says about the alloy when i next see him.Mussels wrote: ↑Sat Oct 01, 2022 10:37 pmThat sounds like it will act like a hinge in an accident so any side mount is probably a good idea.Felix wrote: ↑Sat Oct 01, 2022 10:27 pm
- Has thanked: 2552 times
- Been thanked: 6260 times
It'd say it's more important how you attach the belt rather than worrying about it being 'only' 3cm cross section box aluminium. You could pick the entire van up with a bit of 3cm box section with way thinner walls than you'd think. The bulk strength of the section isn't at issue really (probably - assuming it's not tinfoil thin).
How are you gonna attach it?
I wanted to just drill through two opposite sides of the box section and mount the belt there. Im Blue in this picture is roughly where the seat is and red lines is roughly how the alloy frame sits. Both sides of the door and back end of rear window is steel uprights what i presume is stiffer incase you roll the bus. Behind the seat between slopping and middle window you will see a white dot. This is roughly where the belt will be pulled down from. I was thinking just drill through the alloy from the outside and cap the ugly bolt with a plastic cap. This will be the top mounting point and the lower will have to be on the same strip of alloy at floor level.
- Has thanked: 5453 times
- Been thanked: 13102 times
Get a Mercedes Viano seat, the seatbelt is integrated into the actual item.
- Has thanked: 6199 times
- Been thanked: 5090 times
Is it worth contacting the coachbuilders who, errr, built the coach? They should know what's strong enough as the force generated in high speed impacts can be huge.
- Has thanked: 65 times
- Been thanked: 1235 times
Is the wagon still registered as a bus, if so then a seat belt is not reqd, so fit what you like to keep swmbo happy, then remove it for the test.
The 'stupid question' would be "how do I extract the Mrs from the windscreen?"
Previous owner made a shit attempt to get it registered as a camper. Sofa bed, Chest of drawers and a camping stove Came back as PLG what is a shame as the tax for bus is almost 100 quid cheaper. I will be going for camper after i refit and paint it and as her seat is technically not a front seat she does not need a belt but we would rather have one. I have an idea of adding a steel frame what will work i just need to fathom if the chassis outriggers are strong enough.
Campers under 3.5t are plg anyway, over 3.5t phgv (£165 p/a).Felix wrote: ↑Tue Oct 04, 2022 6:24 pmPrevious owner made a shit attempt to get it registered as a camper. Sofa bed, Chest of drawers and a camping stove Came back as PLG what is a shame as the tax for bus is almost 100 quid cheaper. I will be going for camper after i refit and paint it and as her seat is technically not a front seat she does not need a belt but we would rather have one. I have an idea of adding a steel frame what will work i just need to fathom if the chassis outriggers are strong enough.
If it had stayed as a bus, you'd need a PCV mot which is ministry only and no latitude, and, from memory of my old LDV, fucking expensive.
