What do I need to fit this connector?
- Has thanked: 4366 times
- Been thanked: 2855 times
Want to wire my Sat Nav to the spare live connection behind the headlight of the GSXS. I've just had a look and took some pics. What is it I need to buy to mate into this?
I'm sure I can get on from ebay/amazon etc but no idea what I need.
- Been thanked: 7541 times
Re: What do I need to fit this connector?
Have a browse at https://www.vehiclewiringproducts.co.uk/
Or chop it off and use whatever connector you like.
Thanks mate I'll order one of those, defo looks the same.KungFooBob wrote: ↑Wed Jun 15, 2022 2:37 pm Or just google it.
http://www.cycleterminal.com/hm-non-sealed-series.html
https://kojaycat.co.uk/epages/950000457 ... cts/HM0902
I did consider just chopping it off but felt with a new bike it'd be nice not to bodge it!
- Has thanked: 10279 times
- Been thanked: 6891 times
When I fitted the tail tidy to mine, I bodged all the connections.Supermofo wrote: ↑Wed Jun 15, 2022 2:52 pmThanks mate I'll order one of those, defo looks the same.KungFooBob wrote: ↑Wed Jun 15, 2022 2:37 pm Or just google it.
When I was clearing up I found some nice connectors in the box
- Been thanked: 4125 times
There's a spare connector under the seat on the 750, no idea what it's for.
- Has thanked: 9842 times
- Been thanked: 10156 times
Suzuki approved dildo charge point.Le_Fromage_Grande wrote: ↑Wed Jun 15, 2022 3:08 pm There's a spare connector under the seat on the 750, no idea what it's for.
- Has thanked: 1043 times
- Been thanked: 362 times
Shots firedSkub wrote: ↑Wed Jun 15, 2022 4:04 pmSuzuki approved dildo charge point.Le_Fromage_Grande wrote: ↑Wed Jun 15, 2022 3:08 pm There's a spare connector under the seat on the 750, no idea what it's for.
That's what I store in the top box along with an assortment of rubber fists.Skub wrote: ↑Wed Jun 15, 2022 4:04 pmSuzuki approved dildo charge point.Le_Fromage_Grande wrote: ↑Wed Jun 15, 2022 3:08 pm There's a spare connector under the seat on the 750, no idea what it's for.
I couldn't think of a suitable witty response, so I left it.asmethurst99 wrote: ↑Wed Jun 15, 2022 6:43 pmShots firedSkub wrote: ↑Wed Jun 15, 2022 4:04 pmSuzuki approved dildo charge point.Le_Fromage_Grande wrote: ↑Wed Jun 15, 2022 3:08 pm There's a spare connector under the seat on the 750, no idea what it's for.
So I have the connector but only just getting around to fitting it. Without a volt meter which is live? There's a white/green wire and a black/white wire. Chatting to my brother he's had a look at the wiring diagram and is pretty sure the green/white is live.
I was gonna ride to his and sort it as he has a volt meter but looks like heavy showers all week. But at the moment think I'm better waiting till I can check in case it blows something if I get it wrong?
- wull
- Has thanked: 881 times
- Been thanked: 1552 times
That will explain why the wife is always rummaging about under there on the K7Skub wrote: ↑Wed Jun 15, 2022 4:04 pmSuzuki approved dildo charge point.Le_Fromage_Grande wrote: ↑Wed Jun 15, 2022 3:08 pm There's a spare connector under the seat on the 750, no idea what it's for.
- Has thanked: 261 times
- Been thanked: 1266 times
- Been thanked: 2621 times
Have you a 12v bulb and holder? One wire from the holder to earth on the bike, the other to poke into the connector on the bike. If the bulb lights up then that's the live wire.Supermofo wrote: ↑Mon Sep 05, 2022 7:16 pm So I have the connector but only just getting around to fitting it. Without a volt meter which is live? There's a white/green wire and a black/white wire. Chatting to my brother he's had a look at the wiring diagram and is pretty sure the green/white is live.
Nope. I am completely useless at DIY and mechanics so have very little in the way of useful stuff!!cheb wrote: ↑Mon Sep 05, 2022 7:47 pmHave you a 12v bulb and holder? One wire from the holder to earth on the bike, the other to poke into the connector on the bike. If the bulb lights up then that's the live wire.Supermofo wrote: ↑Mon Sep 05, 2022 7:16 pm So I have the connector but only just getting around to fitting it. Without a volt meter which is live? There's a white/green wire and a black/white wire. Chatting to my brother he's had a look at the wiring diagram and is pretty sure the green/white is live.
- Has thanked: 7822 times
- Been thanked: 2532 times
Either that or pre-order the fire brigade.
- Has thanked: 221 times
- Been thanked: 878 times
On SRADs and SVs, theres a 2 pin plug under the rear seat for the diagnostic too. (A paperclip)Le_Fromage_Grande wrote: ↑Wed Jun 15, 2022 3:08 pm There's a spare connector under the seat on the 750, no idea what it's for.
- Has thanked: 1947 times
- Been thanked: 1292 times
Amazon will deliver you a £11 volt meter tomorrow if you order it now !Supermofo wrote: ↑Mon Sep 05, 2022 7:16 pm So I have the connector but only just getting around to fitting it. Without a volt meter which is live? There's a white/green wire and a black/white wire. Chatting to my brother he's had a look at the wiring diagram and is pretty sure the green/white is live.
You could go even cheaper..
- Has thanked: 486 times
- Been thanked: 1430 times
