Master cylinder
Scoots
Has thanked: 14 times
Been thanked: 1 time
Master cylinder
Post by Scoots »
Hi, does anyone know of a compatible front master cylinder for a ccm404...my Brymbo one has siezed...expensive for a new one...thanks in advance
Re: Master cylinder
Any decent mechanic will be able to rebuild yours.
wull
Has thanked: 979 times
Been thanked: 1858 times
Re: Master cylinder
Post by wull »
Buy a rebuild kit and do it yourself.
Has thanked: 8035 times
Been thanked: 5694 times
Re: Master cylinder
This lot will do it for £49.50 apparently.
https://racesparesuk.com/product/brembo ... er-repair/
Scoots
Re: Master cylinder
Post by Scoots »
Count Steer wrote: Thu Sep 01, 2022 7:54 pm This lot will do it for £49.50 apparently.
I've spoken to these today...apparently can't get the seals for original Brembo but can do the race spec ones... :?
Scoots
Re: Master cylinder
Post by Scoots »
wull wrote: Thu Sep 01, 2022 7:46 pm Buy a rebuild kit and do it yourself.
Not sure about that lol
Scoots
Re: Master cylinder
Post by Scoots »
Yorick wrote: Thu Sep 01, 2022 7:45 pm Any decent mechanic will be able to rebuild yours.
It's finding one... :think:
Re: Master cylinder
Scoots wrote: Thu Sep 01, 2022 8:09 pm
Somebody on here will know someone :)
Scoots
Re: Master cylinder
Post by Scoots »
Yorick wrote: Thu Sep 01, 2022 9:14 pm
Here's hoping....thanks
Re: Master cylinder
What caliper has it got?
Scoots
Re: Master cylinder
Post by Scoots »
Le_Fromage_Grande wrote: Fri Sep 02, 2022 6:08 am What caliper has it got?
Its a single disc brembo system...I'll have to check serial numbers later for more precise details
Re: Master cylinder
Scoots wrote: Fri Sep 02, 2022 6:52 am
How many pistons, basically is the trail or supermoto?
If it's the trail you want an 11mm master cylinder, I might have a Brembo one from a Husky in the garage, if it's the supermoto you want a 1/2 inch or 13mm, DRZ400 master cylinders are 1/2 inch, but so are loads of other bikes, and you can get new pattern master cylinders off eBAy for not much, just don't buy the stupidly cheap ones.
Re: Master cylinder
Le_Fromage_Grande wrote: Fri Sep 02, 2022 9:01 am just don't buy the stupidly cheap ones.
Because they're usually cheap Chinese copies made of monkey metal.
Re: Master cylinder
Scoots wrote: Thu Sep 01, 2022 8:08 pm
I assume from that, that all the refurbish kits on-line aren't original Brembo then. :( (Otherwise you could send them the MC with the kit). Don't think I'd want to use iffy bits in the front brake system. What's the issue with race spec?
Re: Master cylinder
Rebuild kits are available and simple to fit, however you say it's seized.
To me that means there's corrosion in the bore and it will need honing out rather than just seals, so might not be a DIY job to do properly.
iansoady
Has thanked: 72 times
Been thanked: 244 times
Re: Master cylinder
Post by iansoady »
KungFooBob wrote: Fri Sep 02, 2022 9:07 am
Well I bought this one https://www.ebay.co.uk/itm/313949787916 which is of course Chinese but actually seems to be quite well made and decent metal. It certainly works very well. The truth is that much stuff you buy however branded will be made in the Far East anyway. I'm old enough to remember when "made in Japan" was the sign of cheap rubbish.........
Scoots
Re: Master cylinder
Post by Scoots »
It's the trail...the 404 dual sport model not the supermoto...cheers
Re: Master cylinder
Have a look on the master cylinder and somewhere (probably underneath) it will say what size it is, I think it will be an 11 or 12, but could be a 1/2 or 13, once you've found the size, just buy another master cylinder the same size.
Scoots
Re: Master cylinder
Post by Scoots »
Le_Fromage_Grande wrote: Fri Sep 02, 2022 4:08 pm Have a look on the master cylinder and somewhere (probably underneath) it will say what size it is, I think it will be an 11 or 12, but could be a 1/2 or 13, once you've found the size, just buy another master cylinder the same size.
OK I will look now cheers
Scoots
Re: Master cylinder
Post by Scoots »
It's stamped 11 underneath..I'll have a look for a replacement now..thanks
