Fitting a brake lever guard
tricol
Has thanked: 235 times
Been thanked: 471 times
Post by tricol »
Yea, I know RTFM. Accept, I would have, if the part came with one. Not available to download on the R&G site as it says 'fitting instructions coming soon'. Great. I've tried fitting it with the bits it comes with, as far as I can tell it only goes together one way. When it is fitted, it's not tight enough. I can easily move it up and down. I don't want to over tighten it and I'm positive it will break with it being a plastic part.
I've contacted R&G, I hope they can sort it. Otherwise i'll need to buy another one, with 3 working day until I leave for Pembrey. And yes, I would have had it sooner hadn't R&G messed me about with my original order.
Urgh. I hate bike DIY.
Yamaha MT09 SP
Has thanked: 599 times
Been thanked: 2443 times
Re: Fitting a brake lever guard
I don't imagine the fitting kit is any different to any of the other guards they use, so follow one of them;
https://assets3.rg-racing.com/Images/fi ... CTIONS.pdf
If'n it were me I'd wrap a bit of tape or a bit of inner tube around the expanding part so it's got something with a bit of give to snick up against that alos will have a bit more friction
Has thanked: 10265 times
Been thanked: 6886 times
tricol wrote: Sat Aug 27, 2022 5:41 pm Yea, I know RTFM. Accept, I would have, if the part came with one. Not available to download on the R&G site as it says 'fitting instructions coming soon'. Great. I've tried fitting it with the bits it comes with, as far as I can tell it only goes together one way. When it is fitted, it's not tight enough. I can easily move it up and down. I don't want to over tighten it and I'm positive it will break with it being a plastic part.
Plastic? If it's so fragile it won't do its job :(
The plastic ones are a bit crap, but the only answer is tighten it more, the Acerbis ones are good, but they aren't cheap
Has thanked: 1746 times
Been thanked: 2085 times
I've got one in the garage i can bring down. Lots of clever people available to fit it for you, no worries. 👍
tricol
Post by tricol »
Thanks for the replies. This is the lever: https://www.rg-racing.com/browsebike/Tr ... rettyPhoto
I know it's not the most expensive, but didn't see value in spending over £100 for my first trackday.
I've managed to get it tighter by fitting another washer to it. The problem is that the bars are not hollow at the end, they're threaded. I assume this is for OEM bar end mirrors and end caps.
Yamaha MT09 SP
Has thanked: 5451 times
Been thanked: 13087 times
Yorick wrote: Sat Aug 27, 2022 6:20 pm
R&G is plastic but it's plenty strong enough. They're required to deflect an impact from another bike alongside, not survive a nuclear attack.
Let's be honest, people fit them to keep track day organisers happy, TDOs want them because the insurance company wants them, no one really cares if they work or not.
twids
Has thanked: 43 times
Been thanked: 49 times
Post by twids »
Slight topic detail... I've just fitted some R&G ones to mine for next weekend, doesn't look they'll do much good on shorty leavers but maybe I've fitted it wrong?
twids wrote: Sun Aug 28, 2022 12:38 pm Slight topic detail... I've just fitted some R&G ones to mine for next weekend, doesn't look they'll do much good on shorty leavers but maybe I've fitted it wrong?
Well it's fitted, looks correct but looks completely useless
Still do the job though. 👍
