Another networking Q
Has thanked: 2259 times
Been thanked: 1245 times
Just configuring ethernet backhaul and am using a cable tester to trace all the cables.
All OK except for cable that runs to our pool room and that has pins 1 & 2 crossed, from Googling its a crossover - assume for the use I have I need 1 & 2 to go to 1 & 2 at the other end?
Has thanked: 6416 times
Been thanked: 4798 times
Re: Another networking Q
Can't help but I am intrigued. :D
What's a 'backhaul' and, if the place is ethernet cabled, has it been done incorrectly or something? I assumed you just ran cables from a hub to sockets where you needed 'em. :hmmm:
Has thanked: 609 times
Been thanked: 4133 times
If you want a straight cable yes, you should keep the cables as pairs to prevent crosstalk (a form of interference)
10mbps uses a single pair
100mbps uses two pairs oranges and greens
1gbps used all 4 pairs
White orange = 1
Orange = 2
White green = 3
Blue = 4
White blue = 5
Green = 6
White brown = 7
Brown = 8
Whole house is networked but I run a WiFi mesh system, apparently benefits can be had by connecting the mesh access points to ethernet as it then allows transmission by WiFi but the return is via ethernet, freeing bandwidth or whatever tech bods call it.
Probably a crock of shit but sounds plausible, time for wine now :thumbup:
Has thanked: 840 times
Been thanked: 1242 times
The crossover was probably deliberate for connecting to a hub, I haven't seen them used for years as it's all switches now. You could rewire the plug but unless you are practiced at it I'd spend a couple of quid on a cheap converter to plug in and swap it back.
It's been many years since I've done any physical networking so details may be off.
Mussels wrote: Sat Aug 27, 2022 8:33 pm The crossover was probably deliberate for connecting to a hub, I haven't seen them used for years as it's all switches now. You could rewire the plug but unless you are practiced at it I'd spend a couple of quid on a cheap converter to plug in and swap it back.
I rewired the faceplate- credit card as a punch down tool :thumbup:
v8-powered wrote: Sat Aug 27, 2022 6:53 pm Whole house is networked but I run a WiFi mesh system, apparently benefits can be had by connecting the mesh access points to ethernet as it then allows transmission by WiFi but the return is via ethernet, freeing bandwidth or whatever tech bods call it.
If you connected your mesh access points to cable the back haul would be done over the copper, they'd work like normal APs, you'd get better bandwidth between APs and the WiFi devices would work better because the radios in the APs are only servicing clients, not doing connections between APs.
Mesh solutions are okay so long as they don't have problems, at which point they become utter arses to work out what's wrong, as one bad client can mess up the whole network.
wheelnut
Has thanked: 911 times
Been thanked: 1010 times
Post by wheelnut »
What the cheese says. If all your APs are connected to a switch then it’s not a mesh. But that’s good, if the points are available then yes, you should use them. A mesh is for when you have no cabling available.
With the cabling, as long as the cables are all punched down on the same terminals on both ends then it will be fine. You don’t want any crossovers.
Well it all seems to work so no drama, just wish we had a faster connection!
