Recommend me a 3 tonne trolley jack
Has thanked: 15949 times
Been thanked: 10243 times
Recommend me a 3 tonne trolley jack. Advantages/disadvantages of a low entry one?
TIA
DefTrap
Has thanked: 2259 times
Been thanked: 2191 times
Re: Recommend me a 3 tonne trolley jack
Post by DefTrap »
I have a cheap one. Not like wish.com or anything like that but prolly off the shelf at the supermarket. Obviously I also use axle stands as I'm not mental but thinking about it they're also cheap ones from the supermarket. Belt and braces anyway.
Has thanked: 599 times
Been thanked: 2435 times
https://www.halfords.com/tools/garage-w ... 57321.html
Get under low cars, solid as, but does weigh an absolute fucktonne
Druid
Has thanked: 276 times
Been thanked: 896 times
Post by Druid »
I have a Halfords one. From previous experience they tend to last between 6 and 10 years before the seals start leaking and I buy a new one.
Current one is a low profile which I bought to fit under a BMW iirc. They don't lift as high and this particular one won't lift the front wheels of my VW Crafter off the ground so I have to use a block of wood between jack and sill.
Druid wrote: Wed Aug 24, 2022 6:43 pm I have a Halfords one. From previous experience they tend to last between 6 and 10 years before the seals start leaking and I buy a new one.
Thats my worry with a low entry, it wont have enough height to lift my camper up.
Druid
Post by Druid »
Specs will usually quote max. lift so you can check if it's enough lift, but you won't need a low entry for the camper
Has thanked: 836 times
Been thanked: 1238 times
I bought a standard budget one as my two ton jack couldn't lift the transit high enough to remove a wheel.
It was about 4 times the size and weight of the 2 ton and apart from trying to move the thing it was perfect.
Has thanked: 10263 times
Been thanked: 6885 times
Taipan wrote: Wed Aug 24, 2022 6:48 pm
The mighty Duster has high ground clearance. So carry various sized wooden lumps to sit the jack on.
I would have needed a block of wood several inches thick for the transit, every scenario I ran through in my head ended in disaster.
Mussels wrote: Wed Aug 24, 2022 7:19 pm I would have needed a block of wood several inches thick for the transit, every scenario I ran through in my head ended in disaster.
I always carry four 3ft planks to put under the wheels if we ever get stuck.
I lift the car with those if necessary.
Has thanked: 9825 times
Been thanked: 10144 times
Yorick wrote: Wed Aug 24, 2022 7:43 pm
Did Iron Bru Freak tell you where to get the planks?
Skub wrote: Wed Aug 24, 2022 8:00 pm
From the shop that sells sky hooks and tartan paint :)
Yorick wrote: Wed Aug 24, 2022 8:08 pm
And that old favourite,the black iridium visor. :thumbup:
This is looking like the winner! Will chuck some new stands in as well.
https://www.machinemart.co.uk/p/clarke- ... trolley-j/
Has thanked: 2903 times
Been thanked: 2052 times
I've had a Clarke jack for around 15yrs now - not that exact one, it's a little less compact. You'll not go wrong with it.
