Ahoy there sparkies!
- Trogladyte
- Has thanked: 68 times
- Been thanked: 89 times
I have a conundrum.
In the hall downstairs there are two lights that operate together, controlled by two switches, at opposite ends of the hall. Its a pretty standard setup. The bulb at the kitchen end blew, and i kept forgetting to fix it. And then I noticed hat the bulb at the front door end would not switch off completely. Switched on it is bright, but switched off it is dim. If I replace the blown bulb with a 15w LED this behaviour continues - switch on, and both lights on. Switch off and the kitchen end goes off, and the front door end goes dim. If I replace the bulb at the kitchen end with an incandescent, it all works normally.
The only thing that is noticeably different to standard that i can see is the switch at the kitchen end, which is a light sensitive thing that can be set t turn the lights on at night when you are on your hold, but it is switched to normal operation, and I cant see how that could cause this effect.
Thoughts?
Thoughts?
- Has thanked: 6189 times
- Been thanked: 5087 times
Re: Ahoy there sparkies!
Your house is haunted. Move immediately?
- Has thanked: 666 times
- Been thanked: 704 times
- Been thanked: 7530 times
Sounds like an Earth Leak, the Earth is leaking the souls of the dead into your house.
- Has thanked: 9828 times
- Been thanked: 10145 times
Shoggoths in the wiring.
- Has thanked: 10264 times
- Been thanked: 6886 times
Same here on lower staircase . All 3 lights emit a light glow which is just enough to see by at night
Our sparky explained it away.
- Has thanked: 836 times
- Been thanked: 1238 times
I've had this occasionally, I suspect it's lights that use transformers. Because a transformer is still connected to neutral when switched off it still gets a sine wave on one side which is possibly enough to produce a small current.
I've never looked into this properly so it's a guess.
