DEATH TO PETROL: UNTITLED’S ELECTRIC SUPERMOTO CONCEPT
- Has thanked: 5455 times
- Been thanked: 13103 times
- Has thanked: 839 times
- Been thanked: 1242 times
Re: DEATH TO PETROL: UNTITLED’S ELECTRIC SUPERMOTO CONCEPT
Death to petrol, as long as you are only riding round the block.
Otherwise I like it.The range is dependent on your style of riding—DTP is about urban fun rather than long countryside rides.”
- Has thanked: 6382 times
- Been thanked: 4768 times
I rather like it.
Not in the wet though and if it's a city bike it needs a bit more weather protection.
Some interesting design ideas.
- Has thanked: 9845 times
- Been thanked: 10156 times
It might be ok when it's finished.
Under 70kgs would be fun.
- Has thanked: 1264 times
- Been thanked: 1188 times
Unsprung weight
Cheaper of the shelf parts
Would look too different
I would like to know technical reasons why not, I know big hubs and short spokes can be problematic but I suspect the answer is it was just too much work to bother trying.
- Been thanked: 4125 times
Yes and no, I like the idea, but not the execution
- ChrisW
- Has thanked: 2921 times
- Been thanked: 2061 times
I think it's good as a concept for moving electric bikes away from either being either too 'futuristic' in style or trying to look like ice bikes. It's original.
I thought it looked quite small until I saw the pic with a rider on it in the article. The thick tubing's deceiving & the seating position is horrible!
- Has thanked: 2553 times
- Been thanked: 6262 times
Hub mounted motors are direct drive, which means big torque, which means big cost.
Not worth it on your dinky urban bike. Gear ratios are a wonderful thing.
Hub mounted motors with a planetary gearbox are possible, but that's massively more expensive than a C+S.
Hub motors with planetary gears have been around on ebikes for years and are cheap, I don't imagine something capable of moving slow motorbike speeds are that much more expensive.
I know I had one like that as I stripped a couple of planet gears and needed to change them.
What didn't work well was the spokes, a mix of cheap spokes, cheap rims, cheap hubs and machine builds gave me no end of problems.
Something else to add to the list of things which didn't workI know I had one like that as I stripped a couple of planet gears
In general terms, getting power from faster spinning, lower torque motors is gonna be cheaper and more efficient than the other way around. That's a pretty generic statement of course.
It had done about 15,000 miles by the time I had a problem, I was surprised such flimsy nylon cogs did so well. The motor had enough power to carry me uphill on throttle only (old British regulations were different) so shouldn't be too difficult to scale up.Mr. Dazzle wrote: ↑Tue Aug 09, 2022 8:36 pmSomething else to add to the list of things which didn't workI know I had one like that as I stripped a couple of planet gears
It is
It's not that it's impossible, it's just that - as you alluded to earlier - the risk/reward isn't worth it for these small start ups.
We're only just starting to consider wheel motors and we're proper nerds with the backing of a huge OEM
- Been thanked: 7543 times
- Has thanked: 2409 times
- Been thanked: 3639 times
Whenever I see one of these electric bikes and their designer/creator is spouting about it being an urban bike, I switch off. The only reason I ride bikes in urban areas is so I can get out of them and go and play in the countryside, where there are far less vehicles, people, speed cameras and cops. So their idea of what constitutes motorcycling is so far away from mine that I really shouldn't even bother spending time on their creation.
Basically 'urban' electric bikes are swerving the big problem that bedevils EVs and in particular EBs - range - and trying to make out it doesn't matter. It does.
