Berd Spokes
Has thanked: 2942 times
Been thanked: 1883 times
Berd Spokes
The LBS took delivery of these today. Kevlar/plastic spokes by Berd. Supposedly save 200g or so off a wheel compared to normal spokes. You have to use a grinding bit to smooth out your hub holes so hub shell warranty is voided. Apparently the build and tensioning process is a three day job to allow the spokes to settle after building and tensioning.
Has thanked: 1829 times
Been thanked: 1469 times
Re: Need Spokes
TBH, I could save that by taking a dump before I ride - and eating less in general .... :thumbup:
Re: Berd Spokes
Do they work?
Re: Berd Spokes
Apparently they do, they’re ideal for XC and trail stuff and as it’s weight off the wheel it’s more noticeable. They also make the wheel a little more flexy which as a lighter rider I think helps with edge grip.
Better write up here(I need to go to bed)
https://www.mtb-mag.com/en/tested-berd- ... elset/amp/
