Glad you are happy with it.weeksy wrote: Sat Aug 06, 2022 8:26 pm
So how's the van? Well I'm 125 miles and several journeys in now and it's brilliant. It drives lovely and nicely. The engine is getting a bit revvy/noisy over 70, but other than that it's lovely and quiet to drive.
Gearbox is smooth, if a little long between some gears.
Try doing a reset on the gearbox adaptations and it will learn your driving style.
See here https://www.mercedesmedic.com/reset-mer ... tructions/
At 70mph, you should be sitting around 2000rpm so engine shouldn't be to noisy.
is it changing up to top gear at this speed??
It will more than likely be the 7 speed auto in yours so you should not be above 2000rpm if you are in 7th gear at 70mph.
Try a reset first and see where you are. Probably just needing a reset and to relearn your driving style.
