Can I connect a landline phone to my router and use it as a voip
Demannu
Has thanked: 65 times
Been thanked: 1235 times
Post by Demannu »
Got a huawei cube router and a couple of mobiles, but reception is poor here, so there's a lot of ' can you still hear me?'
Was wondering if a digital phone would double up as a VoIP? We can use WhatsApp etc so I know our 4g is strong enough for VoIP.
Ditchfinder
Has thanked: 631 times
Been thanked: 719 times
Re: Can I connect a landline phone to my router and use it as a voip
Post by Ditchfinder »
Check to see if your mobile allows calls over mobile data/wi-fi - this will be easier than setting up a voip line
Has thanked: 609 times
Been thanked: 4133 times
Depends on the router, some of them have analogue voice ports, and it will have to register with a VOIP provider
wheelnut
Has thanked: 911 times
Been thanked: 1010 times
Post by wheelnut »
Voip is still hit and miss over 4G. Some carriers cope with it better than others. You would need to buy a voip service and port your landline across to it.
Alternatively, cancel your landline and get the number ported to a provider that can point your landline to a mobile.
Has thanked: 840 times
Been thanked: 1242 times
I used to have a box from https://www.vonage.co.uk/ that connected a normal landline phone to a VoIP account. It worked well and must have been fairly cheap as I used it instead of getting a second line.
Slenver
Has thanked: 650 times
Been thanked: 865 times
Post by Slenver »
Just enable Wi-fi calling. Needs to be done on your phone as well as with your provider but sorts the issue.
I had to move from giffgaff who didn't support it, but all the main first party providers do. Meant that I could ditch the landline and go from very, very patchy mobile signal to perfect calls/texts via WiFi.
