Does anyone have a good overview of multi room audio?
Trogladyte
Has thanked: 72 times
Been thanked: 106 times
Post by Trogladyte »
I don't quite know what I need. I've got an Audiolab music streaming box running into sn Audiolab, which is driving a lovely set of B&Ws. This is all linked up with the Xbox & the TV. The music runs on Data Play-Fi.
Meanwhile in another part of the forest, my turntable, CD changer and tuner, all run into an old Cambridge Audio amp, driving a pair of Wharfedales and a pair of Tannoys together.
How do I link the second system with the first? Do I need a network amp? Will that allow me to use the Audiolab streaming box as a source?
Trogladyte
Re: Does anyone have a good overview of multi room audio?
Blimey. That'll be a no" then.
Has thanked: 8048 times
Been thanked: 5698 times
Soz. :(
I'm a 'route one to goal' sort of chap when it comes to technical solutions for hi-fi. Ditched the bits and bobs systems and bought things that work together pretty seamlessly. Wouldn't know where to start with your systems. Surprised no-one else doesn't though.
Has thanked: 1926 times
Been thanked: 1728 times
No idea - I just run two systems in different rooms separately
They are linked via the on computer library/ spotify - but if I want vinyl - I go into the room with the Technics...
Slenver
Has thanked: 692 times
Been thanked: 919 times
Post by Slenver »
Not quite sure how you'd add the two existing halves together, but for reference, I have an Audiolab DAC and power amp and connect a Sonos Bridge into the DAC, then output to Quad speakers. I don't use any other sources (apart from TV/PS4) but could do. Can't remember offhand if the DAC has a phono stage – think from memory that it was an option.
Point being, you can certainly do everything you need with updated hardware – in my case, the same brand even – but not sure about combining your current stuff.
Has thanked: 717 times
Been thanked: 2045 times
Dig deep and get a new system. Sonos or the likes.
Has thanked: 781 times
Been thanked: 1072 times
Trogladyte wrote: Wed Aug 03, 2022 12:30 am Blimey. That'll be a no" then.
Nope, not a clue here.
wheelnut
Has thanked: 929 times
Been thanked: 918 times
Post by wheelnut »
Trogladyte wrote: Sat Jul 30, 2022 11:22 pm I don't quite know what I need. I've got an Audiolab music streaming box running into sn Audiolab, which is driving a lovely set of B&Ws. This is all linked up with the Xbox & the TV. The music runs on Data Play-Fi.
I suspect anything you try and cobble together with that lot will be a bodge and just not work as you want it to.
Your turntable and Cambridge kit are for listening to. Use them for that and keep them separate. A multi room setup is music for convenience, not for listening to. Alexa is as good as anything else.
Has thanked: 780 times
Been thanked: 3224 times
Download BBC sounds on to your phone (other steaming services are available)
Open said streaming service
Put phone in pocket
Et voila you now have a multi room audio in whatever room your pocket is in
Kneerly Down
Has thanked: 135 times
Been thanked: 254 times
Post by Kneerly Down »
wheelnut wrote: Fri Aug 05, 2022 9:29 pmI suspect anything you try and cobble together with that lot will be a bodge and just not work as you want it to.
That^ is what I'd suspect also.
I'm just getting round to setting up (after many years of being in the storeroom) my Arcam amp and Monitor Audio speakers in the study, as I'm working full-time from there now.
In recent years I've been pretty much solely listening to audio either on BT headphones or the full-size Amazon Echo devices. Really looking forward to having some proper sound filling the room once again! :)
I'll still keep the Amazon devices for wandering about the house though.
Slenver
Post by Slenver »
wheelnut wrote: Fri Aug 05, 2022 9:29 pm I suspect anything you try and cobble together with that lot will be a bodge and just not work as you want it to.
No reason to think that. I have a good hi-fi connected into a multi-room Sons system as outlined above. Perfectly straightforward.
wheelnut
Post by wheelnut »
Slenver wrote: Sat Aug 06, 2022 12:19 pm No reason to think that. I have a good hi-fi connected into a multi-room Sons system as outlined above. Perfectly straightforward.
True, you can make anything work if you put your mind to it, but what’s the point? Sonos isn’t Hifi. Streaming isn’t hifi. By the time Trog gets something that can stream into the Cambridge and back out to a multi room setup, he may as well have an independent multi room streaming setup (Sonos, Alexa, whatever) and keep the hifi for listening to.
Slenver
Post by Slenver »
wheelnut wrote: Sat Aug 06, 2022 4:21 pm
Why isn't streaming or Sonos hi-fi? It's 2022 y'know, hi-fi isn't just record decks anymore.
wheelnut
Post by wheelnut »
Slenver wrote: Sat Aug 06, 2022 7:26 pm
Sonos are great, they can deliver reasonable quality, convenient music, but they aren’t in any way comparable to a decent quality hifi setup, either turntable or CD.
The calendar has nothing to do with it. ;)
Slenver
Post by Slenver »
wheelnut wrote: Sat Aug 06, 2022 7:47 pm
I disagree entirely. Sounds like you're just talking about their speakers.
wheelnut
Post by wheelnut »
Slenver wrote: Sat Aug 06, 2022 7:50 pm I disagree entirely. Sounds like you're just talking about their speakers.
Speakers play a part certainly, but music separation and definition starts at the quality of the recording, then the source, the ampflier, the cables and then the speakers. All have to work together to suit the music choice, the listener and the room. Some people prefer the music quite lively and forward (KD’s arcam will be in that corner), and some will prefer it a bit more laid back.
My own setup, a rega planar 3, marantz CD transport, roksan attessa and B&W 603 S2 is a low to mid range setup but delivers a fairly bright sound without being harsh. I did demo a fair few options to arrive at the above combo though.
One thing that really does apply to hifi is the law of diminishing returns.
Slenver
Post by Slenver »
wheelnut wrote: Sat Aug 06, 2022 8:04 pm
Yes, of course. But if the Sonos is doing nothing other than moving digital information from one place to another then you're relying on the quality of whatever components you choose.
wheelnut
Post by wheelnut »
Slenver wrote: Sat Aug 06, 2022 8:21 pm Yes, of course. But if the Sonos is doing nothing other than moving digital information from one place to another then you're relying on the quality of whatever components you choose.
Yes and no. With Sonos you can choose your source, but the DAC and amplification happens within each Sonos member. Not to mention the loss in wireless transmission.
Dont get me wrong, I’m not saying Sonos are rubbish, they are great for what they are, but they really are a world away from a reasonable hifi setup. It’s horses for courses though, you get what suits your listening preferences.
Slenver
Post by Slenver »
wheelnut wrote: Sat Aug 06, 2022 8:53 pm
No it doesn't, not necessarily. That's what I'm trying to explain. In most cases this is true, but they make other products, including one that simply streams into your DAC and amp. As I explained above in my own setup.
And as for 'loss in wireless transmission', I'm not sure that's a thing. Do you find websites are lower quality on wi-fi than via an ethernet cable? :)
