- Been thanked: 2501 times
Lignum vitae is the wood you want, very hard and used to be used in ship's blocks. Police truncheons used to be made from it too iirc.
- Has thanked: 10117 times
- Been thanked: 6649 times
It was an offcut of the Riga wood that they built our pergola from.DefTrap wrote: ↑Wed Jul 27, 2022 4:45 pm Really? We're not even going to discuss the type of wood used? Oak might last for a bit I spose (it doesn't look like oak) If its pine I reckon it'll last til tomorrow.
That said - I glued the engine on my 406 about 40 thousand miles ago. All the keyboard-experts laughed ....
- Has thanked: 1326 times
- Been thanked: 1652 times
It was also used for the ships and even submarine propeller bearings, also for the turbine bearings on the bloke who did up that French River hydro power thing.
Oh and I have four wooden handppanes with it on the soles.
Two of em are made by Ulmia and are nicer to use than I thought they would be.
Not for site use though. For the things I like instead.
- Has thanked: 15614 times
- Been thanked: 9854 times
Does simplybearings not have what you want? If it does, link me to it and i'll get one bought and send it to you.Yorick wrote: ↑Wed Jul 27, 2022 4:24 pmThe bearing finally collapsed today. No shops have anything similarYorick wrote: ↑Thu Jul 14, 2022 11:50 am Ordered standard 46.3mm bearings which Pen's nephew brought over. They are for the wheels on our heavy steel gate.
Wheel came off easily but had to smash the old wheel bearing out. Then I found that the new bearings were only 42mm. Bollox.
I had to bash the old broken shell back in and a few ball bearings so that the wheel will turn. Thankfully the gate still slides, albeit a bit clonky.
So I bodged a wooden bush. Lots of oil and it slides nicely. 2 collets fit inside for the bolt to slide on. Not the wood itself.
Was quite proud of myself
- Has thanked: 852 times
- Been thanked: 1226 times
What he wants has changed, he now wants to point at the gate and say "See that, that's a Yorkshire bearing right there".Taipan wrote: ↑Wed Jul 27, 2022 7:11 pmDoes simplybearings not have what you want? If it does, link me to it and i'll get one bought and send it to you.Yorick wrote: ↑Wed Jul 27, 2022 4:24 pmThe bearing finally collapsed today. No shops have anything similarYorick wrote: ↑Thu Jul 14, 2022 11:50 am Ordered standard 46.3mm bearings which Pen's nephew brought over. They are for the wheels on our heavy steel gate.
I can't get the outer shell out. No way to force it out. But Muchas gracias amigoTaipan wrote: ↑Wed Jul 27, 2022 7:11 pmDoes simplybearings not have what you want? If it does, link me to it and i'll get one bought and send it to you.Yorick wrote: ↑Wed Jul 27, 2022 4:24 pmThe bearing finally collapsed today. No shops have anything similarYorick wrote: ↑Thu Jul 14, 2022 11:50 am Ordered standard 46.3mm bearings which Pen's nephew brought over. They are for the wheels on our heavy steel gate.
- Has thanked: 5504 times
- Been thanked: 12764 times
Dremel. Loads of YouTube videos
Good idea. Just access from front. So can't attack it properly.
Gonna get a new one if I can
- gremlin
- Has thanked: 776 times
- Been thanked: 4515 times
Got up, still feeling the effects of covid, like my brain is in a fog. The word 'drained' doesn't begin to explain it. Had arranged to go into the office for some collaborative meetings. I'm halfway in when I suddenly realise I have forgotten my work phone, log in card and other bits I need. I do a U turn and head the 20 minutes back home. I park the bike on the drive, run in, get my stuff and, as I faff around with the tail pack, the bike rolls off the side stand. I can only assume I hadn't locked it in place properly. Net result a broken clutch lever, scraped engine guard and broken tail pack, which I assume was done as it gouged itself down my right thigh.
Fuck sticks.
Now in work wondering why the fuck I didn't cal in sick today. Mug.
Fuck sticks.
Pillock. I always put myself before work.
- Has thanked: 9691 times
- Been thanked: 9705 times
Everything's clearer with hindsight,but riding with brain fog ain't a great idea.gremlin wrote: ↑Thu Jul 28, 2022 12:19 pm Got up, still feeling the effects of covid, like my brain is in a fog. The word 'drained' doesn't begin to explain it. Had arranged to go into the office for some collaborative meetings. I'm halfway in when I suddenly realise I have forgotten my work phone, log in card and other bits I need. I do a U turn and head the 20 minutes back home. I park the bike on the drive, run in, get my stuff and, as I faff around with the tail pack, the bike rolls off the side stand. I can only assume I hadn't locked it in place properly. Net result a broken clutch lever, scraped engine guard and broken tail pack, which I assume was done as it gouged itself down my right thigh.
Fuck sticks.
At least,brain fog aside,there's no broken bits on you.
- Has thanked: 216 times
- Been thanked: 668 times
When I was at uni (did I mention my BA Eng. M.O.M.S. ( failed)) we were given steel strip to cut up and the re fix using, weld, rivets and glue.DefTrap wrote: ↑Wed Jul 27, 2022 4:45 pm Really? We're not even going to discuss the type of wood used? Oak might last for a bit I spose (it doesn't look like oak) If its pine I reckon it'll last til tomorrow.
Properly applied glue won hands down (I know I should have used gloves).
- gremlin
Well, got sent home from work as my boss said I looked 'fucking awful'.gremlin wrote: ↑Thu Jul 28, 2022 12:19 pm Got up, still feeling the effects of covid, like my brain is in a fog. The word 'drained' doesn't begin to explain it. Had arranged to go into the office for some collaborative meetings. I'm halfway in when I suddenly realise I have forgotten my work phone, log in card and other bits I need. I do a U turn and head the 20 minutes back home. I park the bike on the drive, run in, get my stuff and, as I faff around with the tail pack, the bike rolls off the side stand. I can only assume I hadn't locked it in place properly. Net result a broken clutch lever, scraped engine guard and broken tail pack, which I assume was done as it gouged itself down my right thigh.
Fuck sticks.
Starting to feel it too. Having what seems like a bit of trouble breathing. Not exactly short of breath, but feels like the old bellows are working at about 90% efficiency. Every once in a while I catch my breath and it hurts a bit.
I must admit, I was s bit arrogant about Capt. Covid as I'm in reasonable shape, as most days I'll go gym, run, weight train, etc. and am in good health generally, but this virus has fucked me over a bit.
Who wants first dobs on the Tiger? You'll have to put a new clutch lever on it, mind....
- Cousin Jack
- Has thanked: 2560 times
- Been thanked: 2183 times
GWS mate, but just in case I'll take the Tiger.gremlin wrote: ↑Thu Jul 28, 2022 4:52 pm
A pal found one in a new ferreteria in the big city. I'd never been before coz it looks small from the front.
But mahoosive inside.
And they had the paint I've been trying to find.
I'll be heading back there when I have more time for a proper perusal. These places take more money off me than Penny spends on shoes
How is the wooden one holding up?
Is he new?gremlin wrote: ↑Thu Jul 28, 2022 4:52 pmWell, got sent home from work as my boss said I looked 'fucking awful'.gremlin wrote: ↑Thu Jul 28, 2022 12:19 pm Got up, still feeling the effects of covid, like my brain is in a fog. The word 'drained' doesn't begin to explain it. Had arranged to go into the office for some collaborative meetings. I'm halfway in when I suddenly realise I have forgotten my work phone, log in card and other bits I need. I do a U turn and head the 20 minutes back home. I park the bike on the drive, run in, get my stuff and, as I faff around with the tail pack, the bike rolls off the side stand. I can only assume I hadn't locked it in place properly. Net result a broken clutch lever, scraped engine guard and broken tail pack, which I assume was done as it gouged itself down my right thigh.
Fuck sticks.
It's on the spare shelf
But it did its job
Fitness doesn't always seem to mean you'll get through it better? I'm an overweight asthmatic and all it did to me was make fall asleep at times. Yet I've heard loads of tales of superfit people that have suffered badly at the hands of this virus.gremlin wrote:
Eat healthy, hydrate and don't overdo it.
GWS
Dr Taipan.
- Has thanked: 6264 times
- Been thanked: 4614 times
A doctor? Hurrah! I'd like to make an appointment......Taipan wrote: ↑Thu Jul 28, 2022 6:46 pmFitness doesn't always seem to mean you'll get through it better? I'm an overweight asthmatic and all it did to me was make fall asleep at times. Yet I've heard loads of tales of superfit people that have suffered badly at the hands of this virus.gremlin wrote:
GWS
Dr Taipan.
The other thing re fitness etc is that the effect of exercise after illness seems to split 50:50 It helps some people get back up to speed quicker while it puts others in a downward spiral. Again it seems to have no correlation with actual fitness pre-infection. I guess your immune system isn't as tightly linked to fitness as some might have us believe.
