Zx6r 1999 hot start issue
- Has thanked: 6376 times
- Been thanked: 4753 times
Re: Zx6r 1999 hot start issue
Sounds similar to the problem I had with a car. Would start cold then act up when warm. Eventually, got to a destination then had to call the RAC as it wouldn't fire at all. Got it towed to the repair place and when they got round to it, it started first time. Had an inkling it was a coil issue as someone had complained it interfered with their tv.
I suppose when it happens you could check to see what the spark looks like? (If a plug is easy to get at).
- Been thanked: 4124 times
Just fit a new pair of coils, they're about £18 each off eBay
- Has thanked: 2551 times
- Been thanked: 6245 times
Was this some time ago?Count Steer wrote: ↑Thu Jun 30, 2022 8:10 am Had an inkling it was a coil issue as someone had complained it interfered with their tv.
Not as long as you might think. About 4-5 years ago.Mr. Dazzle wrote: ↑Thu Jun 30, 2022 6:52 pmWas this some time ago?Count Steer wrote: ↑Thu Jun 30, 2022 8:10 am Had an inkling it was a coil issue as someone had complained it interfered with their tv.
I used to park it in the same car park space every time I used a particular car park - quite frequently. Came back to it one day and found a note under the wiper (in a scrawly hand) saying please park somewhere else as your car interferes with my TV. I was a little surprised as it was in the morning (who watches morning TV!?) and I thought that sort of thing only affected analogue. (I still know when a local yoof is approaching on his poorly suppressed, 50cc of raw power bike if I'm using FM radio though).
The resistors are in the plug caps, not the coil, I don't think a coil would cause telly interference.
Yeah, I'd normally think plug caps. But I had nothing firing on any of the 5 cylinders. The interference thing may be completely coincidental, I wondered about some breakdown in insulation in the coil but who knows? (I also thought telly interference was a thing of the past but they'd got the car clocked so something was occurring).Le_Fromage_Grande wrote: ↑Thu Jun 30, 2022 9:33 pm The resistors are in the plug caps, not the coil, I don't think a coil would cause telly interference.
- Trogladyte
- Has thanked: 68 times
- Been thanked: 89 times
My old Guzzi Le Mans 3 did this. It would start fine from cold, or from red hot, but if it was warm - forget it. My tame Guzzi guy reckoned it was carbs getting too hot, and fuel evaporating in the float chambers. But I was skeptical, as it started fine if red hot. I changed the inlet rubbers for thicker OEM jobbies, plugs and coils and it was much better. But no real idea what fixed it
- Has thanked: 229 times
- Been thanked: 575 times
May not be relevant, but - daughter had a similar problem with her 51 Polo GTi. Started fine when cold, but if she stopped eg for fuel, it wouldn't re start. Happened a few times when she was returning to Wales from us in Cornwall - refuelled 20 miles away, wouldn't start. By the time dad got to her it had cooled enough to start. Turned out to be a faulty temperature sensor. Told the ecu the engine was cold >> richer mix, so won't start. A known problem apparently. New sensor, problem solved.
A long way from your bike, but still...
