In todays news...
Has thanked: 764 times
Re: In todays news...
demographic wrote: Sun Jul 17, 2022 6:58 pm
irie wrote: Sat Jul 16, 2022 9:57 pm Image
That sums Brexit up nicely.
Where did he get the saw from?
Has thanked: 1264 times
Been thanked: 1188 times
Post by slowsider »
gremlin wrote: Mon Jul 18, 2022 9:55 am Where did he get the saw from?
a well-wisher
Has thanked: 5889 times
Been thanked: 4939 times
Until you asked that, it had been assumed that he attracted women with his big chopper.
Has thanked: 1324 times
Been thanked: 1653 times
Its funded by tbe Kremlin and given to him via Arron Banks. Maybe.
http://www.newenergyscotland.com
SIM generator
Magic beans, perpetual motion, or plausible?
https://www.newenergyscotland.com/how-it-works/
Stage one is when the generator is at the top of the water column.
It is much heavier than the water it displaces, and will sink at a high velocity.
By reducing the speed of this descent, the device will generate power until it reaches near the bottom of the water column.
Stage two involves the generator reconfiguring and allowing air at barometric pressure to enter the generator and making it more bouyant.
Detailed analysis and calculation by research experts clearly indicate that due to the unique design, this stage is feasible, and should operate as described.
In Stage three, if the generator is released, it will float to the top of the water column at a high velocity.
By reducing the speed of this ascent, this will generate power until it reaches its starting position near the top of the water column.
Stage four involves the generator reconfiguring again, becoming heavier than the water it displaces, and sinks, which starts stage one of the cycle again.
Has thanked: 256 times
Been thanked: 1244 times
They don’t go far into details. If that means it gets to the bottom, then drains the water in the generator to the outside of the column to allow air into the generator, then that water will have to be replaced in the column, from a source with a higher head than the column.
That would mean it uses the same energy source as hydro-electric power.
JackyJoll wrote: Wed Jul 20, 2022 8:25 am
It seemed to me that the energy used to displace the water and replace with (compressed?) air could exceed that gained from the rise and fall.
Has thanked: 6201 times
Been thanked: 4616 times
Don't these things use off-peak to recharge them then generate during high demand? I thought that was how stuff like Dinorwig worked....pump the water up at night then generate during the day.
Has thanked: 2494 times
Been thanked: 6023 times
Horse wrote: Wed Jul 20, 2022 12:20 pm
Yep.
The falling down bit would work to generate power. The rising back up but would too.
The bit that is "cheating" is filling the thing with air at the bottom of the column. Energr required to do that will be more than you generate and/or the overall height of the column drops like JJ says.
Yes, from what they said, I couldn’t tell if they do it all within the column like that, or keep replacing drained water.
Anyway, it’s unconvincing. Give them a great big subsidy!
Demannu
Has thanked: 65 times
Been thanked: 1235 times
Post by Demannu »
Russia shoots down its own latest and greatest military aircraft by mistake.
Apparently the SU34 has a host of electronic countermeasures, various radar systems to protect it.
So either their anti aircraft missiles are a bit special, or perhaps Moscow overstate the effectiveness of the SU34
Has thanked: 2302 times
Been thanked: 3383 times
Demannu wrote: Wed Jul 20, 2022 1:12 pm Russia shoots down its own latest and greatest military aircraft by mistake.
Or perhaps it's not programmed to detect the profile of 'friendly fire'? Either way. it's a b1t sh1t...
Demannu
Post by Demannu »
I wonder what kind of range she gets kicking on like that.
I have a legal trottinette with a 10ah battery and get 12 miles on 60% charge at dog walking speed. Took it to the local boulangerie (9km trip) at flat chat and had used 50%.
Two of the world's most important people catching covid in quick succession....
https://www.bbc.com/news/world-us-canada-62256544
Me, then Biden. In order of both importance and covid catching.
Has thanked: 462 times
Been thanked: 1374 times
A proper Pasting :D Folk still say that?
https://www.examinerlive.co.uk/news/wes ... d-24518717
Has thanked: 1747 times
Been thanked: 1113 times
This goes some of the way to explaining the queues at Dover.
https://www.cityam.com/govt-rejects-33m ... re-likely/
Has thanked: 814 times
Been thanked: 1226 times
Pirahna wrote: Sat Jul 23, 2022 12:18 pm This goes some of the way to explaining the queues at Dover.
A guy from the port was on telly this morning saying they had installed the extra booths but the French hadn't sent enough staff over to fill them. France blamed a technical fault in the tunnel and the UK called bullshit
Don't know what the problem is but it doesn't look like a lack of booths.
Mussels wrote: Sat Jul 23, 2022 12:28 pm
So it's the fault of the French. Don't they realise that they need us more than we need them?
Hoonercat
Has thanked: 320 times
Been thanked: 312 times
Post by Hoonercat »
Extra booths were installed a few days ago, nothing like leaving it to the last minute.
Eurotunnel traffic is also being hit with long delays today. A long section of the M20 is closed to accommodate thousands of lorries being stacked up, meaning holidaymakers are being sent on a lenghty diversion. One traveller tweeted he'd been waiting 5 hours to get into Eurotunnel and moved about 100 metres in that time. :thumbdown:
Doug Bannister, Chief Executive, Port of Dover said: "Since the UK left the EU, we are subject to full passport checks. Before, all of our freight traffic would go through in about zero seconds and now it's 60 seconds to maybe up to 90 seconds per truck. All of that adds up.
The European Entry Exit System (EES), the way it's currently thought through is that it will work well in an airport, but as of now, there is no technology, no process and nothing designed for vehicular traffic in a busy ferry terminal. This is something that is concerning us because if we don't get that right, everything will stop.
