EL CHERO: HONDA CB750F CAFÉ RACER
- Has thanked: 9845 times
- Been thanked: 10157 times
https://www.bikebound.com/2022/07/14/el-chero/
Shirley that from suspension has so little travel it'd be useless?
That aside,change the bars,plug the triangle and fit a front guard,then it's not bad for a Homda.
Re: EL CHERO: HONDA CB750F CAFÉ RACER
At least it doesn't have bar end mirrors
Should have left the oil tank in the triangle under the seat, and if you're going to upgrade forks and brakes then change the forks entirely so you can get rid of the god awful pivoting calipers.
I have a hearty dislike of LED headlamps too.
Apart from that it's ok, for a CB750 cafe racer
- Has thanked: 1350 times
- Been thanked: 1730 times
Is the rider an midget?
Usual other stuff are mudguards, proper airfilter but apart from that it looks ok for a hobbit to ride.
- Has thanked: 2636 times
- Been thanked: 1523 times
Optical illusion from the balloon tyres?demographic wrote: ↑Fri Jul 15, 2022 4:41 pm Is the rider an midget?
- Has thanked: 2409 times
- Been thanked: 3639 times
Quite like the colour scheme and paint layout of the tank. The rest of it - why did they bother? There is so much that is wrong and very little that is right.
