"Disk Full" error
What can the Admins do to help, any requests for changes, updates, etc.
Tricky
Has thanked: 2568 times
Been thanked: 2681 times
"Disk Full" error
Post by Tricky »
Just got this when trying to open the thread in the trips/touring section
Edit:- just gone back to it and it opended fine now, so just a temporary fart I guess!
Has thanked: 5455 times
Been thanked: 13103 times
Re: "Disk Full" error
Well that's just a little, errrrm bizarre !!!
I'll certainly keep an eye out... but yeah if anyone else gets anything please shout me.
I've just had the same
General Error
SQL ERROR [ mysqli ]
Disk full (/tmp/#sql_60c8_4.MAI); waiting for someone to free some space... (errno: 28 "No space left on device") [1021]
SQL
SELECT l.*, f.* FROM phpbbj6_profile_lang l, phpbbj6_profile_fields f WHERE l.lang_id = 1 AND f.field_active = 1 AND f.field_no_view = 0 AND l.field_id = f.field_id ORDER BY f.field_order
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
FILE: [ROOT]/phpbb/db/driver/driver.php
LINE: 1023
CALL: trigger_error()
FILE: [ROOT]/phpbb/db/driver/mysqli.php
LINE: 195
CALL: phpbb\db\driver\driver->sql_error()
FILE: [ROOT]/phpbb/db/driver/factory.php
LINE: 345
CALL: phpbb\db\driver\mysqli->sql_query()
FILE: [ROOT]/phpbb/profilefields/manager.php
LINE: 169
CALL: phpbb\db\driver\factory->sql_query()
LINE: 323
CALL: phpbb\profilefields\manager->build_cache()
FILE: [ROOT]/viewtopic.php
LINE: 1564
CALL: phpbb\profilefields\manager->grab_profile_fields_data()
Pinged it over to the support/Admins and said "WTF guys?"
Hello,
At the moment the server, where your domain is hosted on, works properly and all its services are up and running.
We have checked SQL server and didn't detected any problems
Please check again and let us know if any issue still persists
Meh.. and Bleurgh
Has thanked: 10279 times
Been thanked: 6891 times
inewham wrote: Mon Mar 23, 2020 7:43 pm Thats a fob-off if ever I saw one - if /tmp maxed out they should have seen it and should have added some space
Yup, that's what I was thinking. Obvious really.
