Has thanked: 2636 times
Been thanked: 1523 times
Count Steer wrote: Wed May 25, 2022 7:51 pm
v8-powered wrote: Wed May 25, 2022 6:50 pm image_0d7a8a82-34b2-4792-9766-4e691480fd9620220525_184849.jpg
It doesn't appear to have any steering....given the ground clearance, that's probably wise. :thumbup:
Appears to be twin cow horn things - not attached to a central steering stem like regular bars.
Has thanked: 1947 times
Been thanked: 1292 times
Post by Jody »
It's possibly on air bags..... but it isn't going round corners on those tyres
Has thanked: 540 times
Been thanked: 7553 times
They ride it at the end, but there's not many corners.
Has thanked: 6385 times
Been thanked: 4780 times
KungFooBob wrote: Fri May 27, 2022 8:18 am They ride it at the end, but there's not many corners.
The suspension is adjustable to compensate for the weight of the rider. :lol: :lol: :lol:
Has thanked: 261 times
Been thanked: 1269 times
It’s so cool the block in the blazer/cardigan ensemble has to play with his willy while he looks at it.
And why stop there!
Traditional French housewife setting off home with the fresh loaf:
The things she does to make them eat the heel!
Has thanked: 1264 times
Been thanked: 1188 times
Post by slowsider »
One up on the usual bar-end mirrors with the top one :)
Needs more CARBON!!!!!
At least it's got RWU forks.
Post by Jody »
They've gone to a lot of effort, I wonder why they didn't go for a full tank cover?
Has thanked: 10291 times
Been thanked: 6903 times
Me and my enduro pals are just discussing this. If it was on this island one of us would have bought it.
But we're not sure how good an auto box is on an enduro bike ???
Has thanked: 9862 times
Been thanked: 10182 times
KungFooBob wrote: Wed Jun 01, 2022 7:46 pm Needs more CARBON!!!!!
Eccentric adjuster on left side and conventional on the right. That's odd. (ha)
Has thanked: 2250 times
Been thanked: 1243 times
Has thanked: 2927 times
Been thanked: 2064 times
Yorick wrote: Sat Jun 04, 2022 4:22 pm Me and my enduro pals are just discussing this. If it was on this island one of us would have bought it.
Husky had a lot of success with autos in the eighties. Can't remember the name of the guy that rode for them but I;m sure they won championships. Larry Roesler maybe...?
ChrisW wrote: Sun Jun 05, 2022 5:02 pm
I think the advert is misleading. Can't find any auto Huskies. He probably has the auto clutch thingy
crust
Has thanked: 606 times
Been thanked: 519 times
Post by crust »
Rekluse are great, especially in tight technical going. Take a bit of getting used to but once you 'get them' they make life so much easier.
The clutch cover is worth it on its own. A lot stronger than standard and increases the oil capacity.
crust wrote: Sun Jun 05, 2022 6:17 pm Rekluse are great, especially in tight technical going. Take a bit of getting used to but once you 'get them' they make life so much easier.
Do you lose engine braking ?
IIRC it's centrifugal, the clutch only activates when the revs drop to tick over. So you should still get engine braking... until the revs drop.
KungFooBob wrote: Sun Jun 05, 2022 6:19 pm IIRC it's centrifugal, the clutch only activates when the revs drop to tick over. So you should still get engine braking... until the revs drop.
Cool. I'm having trouble with left hand and fingers, but ATM it's good exercise. But maybe in future. :obscene-drinkingcheers:
crust
Post by crust »
Yorick wrote: Sun Jun 05, 2022 6:18 pm
Thats the bit that takes some getting used to. As long as the revs are up, then no you don't lose engine braking, however if you let the revs drop then the clutch disengages which is fun on really steep descents as the bike takes off, only requires a blip of throttle then it re-engages and you've got engine braking. Once you get used to it it's not an issue.
They really come into their own on rocky bits as you just don't bother with the clutch, like riding a twist and go scooter.
The clutch is still there if you want to use it like a normal one, even now I use the lever for pulling away on the road, force of habit.
crust wrote: Sun Jun 05, 2022 6:26 pm
Pop over and I'll show you some terrain you've never ridden :obscene-birdiedoublered:
