Suspension Upgrade.
Has thanked: 10266 times
Been thanked: 6887 times
Re: Suspension Upgrade.
weeksy wrote: ↑Tue May 24, 2022 12:59 pm You're allowed to get soapy bubbles on it at times you know.
I only jet wash it when it gets embarrassing 😳
Has thanked: 5451 times
Been thanked: 13092 times
Yorick wrote: ↑Tue May 24, 2022 3:21 pm
And that's not "3 months ago" ?
weeksy wrote: ↑Tue May 24, 2022 3:21 pm
No :obscene-birdiedoublered:
Has thanked: 15960 times
Been thanked: 10248 times
Yorick wrote: ↑Tue May 24, 2022 10:59 am That was easier than expected. Youtube videos helped :)
But gonna get the dude to rebuild it. Don't trust myself and he'll be doing the sag and setup anyway.
Top workshop tip. Remove handle from Jack! :thumbup:
Taipan wrote: ↑Tue May 24, 2022 4:46 pm
Good point. I am a clumsy twat :D
crust
Has thanked: 606 times
Been thanked: 515 times
Post by crust »
Off road bikes long fork travel tends to drag dirt up under the seals.
Get one of these, after every ride put a drop of oil on it and spin it around the fork leg, you'll be surprised the amount of gunge it will collect.
https://www.ebay.co.uk/itm/291311613425 ... BM9syf9J5g
crust wrote: ↑Tue May 24, 2022 7:13 pm Off road bikes long fork travel tends to drag dirt up under the seals.
It's so dry here, there's no dirt to attack the seals, but will try it anyway.
Yorick wrote: ↑Tue May 24, 2022 4:59 pm
You're amongst friends! :D
Taipan wrote: ↑Tue May 24, 2022 9:39 pm
Has thanked: 2636 times
Been thanked: 1523 times
Excellent tip. I have a mate who is the sort that would sit on it to roll up a ciggie.
The Spin Doctor wrote: ↑Thu May 26, 2022 10:49 pm
Was it in the UP position ?
Does he need the bumming hat ?
It lives. Just need to set the sag and give the battery a boost.
Will take it out after my afternoon nap ;)
Beancounter
Has thanked: 2870 times
Been thanked: 554 times
Post by Beancounter »
Yorick wrote: ↑Fri May 27, 2022 2:48 pm It lives. Just need to set the sag and give the battery a boost.
I thought the sag was being set as part of the upgrade? Or is your man coming back to do that?
Took it straight to a really rocky path and instantly disappointed.
Carried on and slowly improved. Back good but the front still jars my forearms.
Maybe I expected too much as the ground here is mainly rock hard.
Came home on same path and it was better, so maybe needs to bed in.
Maybe some fine tuning will help.
Beancounter wrote: ↑Fri May 27, 2022 5:14 pm
Just static sag needed doing and it was spot on.
Didn't need rider sag as the new (fatboy) spring takes care of it.
Well, I'm a lot happier today after tough 4 hour ride. I don't know if things bed in, but it's much more compliant now. It's perhaps not as comfy as I would like, but it certainly 'performs' better on the tough stuff. And even after 4 hours, I had no aches or pains in my arms.
Winners :)
