Tyre pressure weirdness
- Been thanked: 4125 times
I've had a new tyre out on the back wheel of my GSXS, so far so good, got it home and checked the pressure, 25psi, should be 42psi, no idea why the shop set it to 25, so I pumped it up to 42 and thought I'll check it to see if it goes down, so last night at 22:30 it was 41, this morning at 07:30 it was 42.5, tonight at 18:00 it was 39.5, the bike hasn't been ridden.
Could the pressure go up with lower temperatures?
Could it be the tyre mildly expanding as it gets warm lowering the pressure?
- Been thanked: 7543 times
Re: Tyre pressure weirdness
What gauge you using?
I had a digital one that was all over the shop when the battery started to go flat.
It's an old digital Halfords one of unknown vintage, that was another thought. I might have one of those slider things somewhere.
But tonight's 39.5 I checked 4 times (it's now down to 39 because I checked so many times)
- wull
- Has thanked: 881 times
- Been thanked: 1552 times
It's what Suzuki recomend, personally I think 35 would be about right
- wull
What tyres are fitted? Those are the bike manufacturers recommended pressures which have been the case for about 400 years, forget about them. I always have a look at what the recommendations are for the tyres that are fitted, and then fine tune it.
- wull
with that being said if it works then go with it, if it ain’t broke don’t fix it.
- Has thanked: 9845 times
- Been thanked: 10157 times
Temperature will definitely impact on psi readings. I prefer one of those Halfraud's pen type tester. They are simple and more reliable imo.
Pretty sure it's temperature related, it's cooled down here and it's up by 1.5 psi.
- Has thanked: 1751 times
- Been thanked: 2089 times
Dunno, the front is impossible to get at with my pressure guage.
- Has thanked: 2554 times
- Been thanked: 6262 times
That is the reverse of what you'd expect, unless something very odd is going on.Le_Fromage_Grande wrote: ↑Tue May 17, 2022 8:28 pm Pretty sure it's temperature related, it's cooled down here and it's up by 1.5 psi.
Or the temperature is effecting your gauge!
Is it though, the tyre is changing temperature because the outside air temperature is changing, meaning the tyre is expanding when warm, lowering the pressure of the air inside and contracting when cold , raising the pressure, this is different to when you ride on a tyre, when I assume the air inside gets got and expands quicker than the tyre, but I'm not sure of my logic on this one.Mr. Dazzle wrote: ↑Tue May 17, 2022 9:03 pmThat is the reverse of what you'd expect, unless something very odd is going on.Le_Fromage_Grande wrote: ↑Tue May 17, 2022 8:28 pm Pretty sure it's temperature related, it's cooled down here and it's up by 1.5 psi.
Or as you say the temperature effects the guage or the way I'm measuring it.
Last edited by Le_Fromage_Grande on Tue May 17, 2022 9:10 pm, edited 1 time in total.
- wull
- Has thanked: 2636 times
- Been thanked: 1523 times
Nope, the static tyre itself won't expand when warm - at least, not that I have ever heard - but the air inside it will, which means the pressure goes up. Not by much, mind. Across a typical 10c night to 20c day, my calculations (Gay-Lussac's Gas Law) suggest that the variation would be around 1.5 PSI.Le_Fromage_Grande wrote: ↑Tue May 17, 2022 9:08 pmIs it though, the tyre is changing temperature because the outside air temperature is changing, meaning the tyre is expanding when warm, lowering the pressure of the air inside and contracting when cold , raising the pressure, this is different to when you ride on a tyre, when I assume the air inside gets got and expands quicker than the tyre, but I'm not sure of my logic on this one.Mr. Dazzle wrote: ↑Tue May 17, 2022 9:03 pmThat is the reverse of what you'd expect, unless something very odd is going on.Le_Fromage_Grande wrote: ↑Tue May 17, 2022 8:28 pm Pretty sure it's temperature related, it's cooled down here and it's up by 1.5 psi.
- Has thanked: 6382 times
- Been thanked: 4770 times
Coefficient of thermal expansion of air is way higher than rubber. I'd try another gauge.
The tyre itself will expand, s'just that the air inside it will expand alot more.
I'd be more inclined to believe the temperature effects the battery voltage in the sensor or something like that.
How good are cheapo sensors anyway?
I did say it was weird, it probably is the guage, that would make more sense, it's not exactly a scientific instrument.
But it is interesting from a perspective of those people who say they can feel the difference in 0.5 psi tyre pressure, I know I can't feel the difference 5 psi makes.
