Lighting problem
- Has thanked: 215 times
- Been thanked: 676 times
Lighting problem
Ok...I know I should have marked it first....
I am moving the kitchen ceiling light.
Pulled down the existing (working ) fitting...made a hole through into the loft above the kitchen for the new lamp. By the time I had dug a hole in the loft floor to find the existing cables and pulled them up, I couldn't remember which lines went where.
There are two twin and earths into the old fitting...leaving two reds and two blacks. The lamp is connected to a chocolate block.
I have tried the two reds together. The two blacks together, 1 red and 1black in a variety of combinations and mixed pairs and singles in other combinations.
It seems one is always live with the power on.
I either have no light or a permanent light. Its very frustrating as the cables are a bit tight so I am working on my nose iyswim,
I am sure one of the blacks was not connected originally, but of course it could have pulled out when I lowered the fitting.
Is there any one that can point me in the right direction?
TIA.
TIA.
Re: Lighting problem
I think I have it (By Jove, he's got it!)
S'obvious innit...
There is no ongoing loop as its an extension with just one lamp. So..the permanent live will connect to the black of the other cable..the other red will go to the lamp, the black from the permanent live goes to the otherside of the lamp.
Not tonight....listen for the bang in the morning.
S'obvious innit...
- Has thanked: 827 times
- Been thanked: 1231 times
Something doesn't sound right. I'd expect three twin and earth cables to a normal light fitting, loop in, loop out and switch, the neutral on the switch cable is actually the live feed into the lamp itself and should have red tape or sleeve around it to show it's a live wire.
Is this light one of a few that are all switched on together by one switch? Are there multiple switches for the same light?
It's difficult to suggest anything as I don't know what's there and I am not an electrician, I would suggest you Google how UK lighting circuits are wired, it's not intuitive but also not complicated.
Randomly connecting wires and hoping for the best could end in disaster.
Definitely 2 twin and earth...i think its just an add on spur...and dont forget this is wales...
Avoided disaster as there is a elt on it..swmbo'd is running back and forth turning the breaker off and on...of course, she might "accidently" get it the wrong way.....
- Has thanked: 10094 times
- Been thanked: 6793 times
Oh yea of little faith.....
Well, 1888, don't buy any grapes.
As I thought, it was a case of permanent live and switch, no loop. Fitted and the new lamp is hanging....a bit skewiff.
I am just waiting for swmbo'd to say
"Can't stand that, put it back as it was"
The new shade (2nd hand) is an acid yellow bamboo thing and I suspect it was machined a little off.
- Has thanked: 6020 times
- Been thanked: 4995 times
Ooh that's a good addition for the book of excuses
