Speed triple 955i
Has thanked: 2250 times
Been thanked: 1243 times
Re: Speed triple 955i
BBB wrote: Thu Mar 17, 2022 2:12 pm Had read about the starter issues, asked the seller if it spins when hot and it does but doesn't fire up and it does. Going to see if I can have a look at the weekend to see if it's a slow spin or possibly another issue.
Don't quote me but believe that the ECU sees low voltage due to excessive power draw by the starter motor, so shuts off the ignition causing no start. Strong battery and associated cabling required to help.....
Been thanked: 7543 times
v8-powered wrote: Thu Mar 17, 2022 3:01 pm
That's to stop it not turning over fully, back firing and taking out the sprag, iirc.
BBB
Has thanked: 294 times
Been thanked: 79 times
Post by BBB »
Sounds like a spinning starter doesn't mean it's not an issue if that makes sense.
Has thanked: 1874 times
Been thanked: 2171 times
Check draglink bearings. Mine are totally shot on my 2001 Speed Triple.
Has thanked: 2554 times
Been thanked: 6262 times
My one went through a spate of refusing to start when hot. No warning lights or other symptoms, it would just merrily spin away and not catch.
I say "went through a spate"...it would still do it, if it weren't for the fact its laid up in my garage.
Trogladyte
Has thanked: 68 times
Been thanked: 89 times
Post by Trogladyte »
I had one and loved it. It was very reliable, although the sprag cluvh fsled.
Has thanked: 1264 times
Been thanked: 1188 times
Post by slowsider »
Trogladyte wrote: Sun Mar 20, 2022 12:37 am although the sprag cluvh fsled.
I hate it when they do that ;)
Dyslexic sprag clutches are a real pain, it does not know if it is in the right order or not.
Trogladyte
I may have had a couple of drinks, last night. 🥃
Has thanked: 2636 times
Been thanked: 1523 times
Only a couple?
Trogladyte
The Spin Doctor wrote: Sun Mar 20, 2022 12:11 pm Only a couple?
A baker's couple.
BBB
Post by BBB »
Went to see it at the weekend and unfortunately it's cost me over £3k but that does include delivery.
BBB
Post by BBB »
Looking to replace the standard starter circuit cabling with some heavier gauge. Can find a kit for the tiger 1050 on square deals website but nothing for the 1050.
Anyone able to recommend some suppliers to check?
Thanks
Search for a guy called Jeff 'pudding' Halford on FB, he makes them.
BBB
Post by BBB »
@v8-powered cheers, the dealer mentioned something like pudding or pies but couldn't remember. Thank you
Looks like I'll to join Facebook....
BBB wrote: Sat Apr 02, 2022 8:51 pm @v8-powered cheers, the dealer mentioned something like pudding or pies but couldn't remember. Thank you
https://www.facebook.com/jeff.p.halford
