What battery?
GuzziPaul
Has thanked: 59 times
Been thanked: 195 times
What battery?
Post by GuzziPaul »
The Tuono failed to start yesterday morning, despite starting the night before. Left it charging all day and it it started fine last night but only showed 11.4V on the built in meter and the same this morning after charging all night.
I'm currently using a Motobatt battery that has lasted about 2 years, similar to the last one it had. I've had the bike from new and this will be the 5th new battery I've put in it.
Recommend me a battery please, do I go cheap and change it every year or stick with Motobatt?
Has thanked: 5377 times
Been thanked: 12767 times
Re: What battery?
I've always gone Yuasa. But i think a lot depends on the use/cold/storage.
The Motobatt i had once i didn't like, but many rave about them.
Has thanked: 524 times
Been thanked: 7244 times
Re: What battery?
Cheapest.
Tayna.co.uk is your friend.
Hairybiker84
Has thanked: 70 times
Been thanked: 108 times
Re: What battery?
Post by Hairybiker84 »
My Motobatt that was on the GS didn't last (or perform) any better than any other battery I've experienced - replaced it with a Yuasa.
Try the thebatteryshop.co.uk, They've beaten Tayna on the last couple of batteries I've bought, often additional discounts for subscribing to their newsletters, etc.
Ditchfinder
Has thanked: 567 times
Been thanked: 631 times
Re: What battery?
Post by Ditchfinder »
I've been using a Lithium battery on the Guzzi and it's lasted 2 winters with no need for a charge despite being tucked up for 5 months both years.
'07 Griso 1100 7 '94 Sprint 900
Has thanked: 15285 times
Been thanked: 9862 times
Re: What battery?
I remember reading somewhere (but can't find it) that Motobatt outperformed a lot of same CCA spec batteries, by holding their cranking amps longer? With a Tunono that has got to be a good thing?
Ditchfinder
Re: What battery?
Mine is a Shido LiFePO4 LTX20CH-BS. It cranks the Guzzi over better than the old one did. I paid about £120 but they're £175 ish now !
Has thanked: 987 times
Been thanked: 1723 times
Re: What battery?
I tend to go for motobatt as they seem to offer decent specs at a decent price. Everything will die if let go flat though so I always use trickle chargers.
Has thanked: 1752 times
Been thanked: 1408 times
Re: What battery?
As my triumph is one of those that suffers from a delicate sprag clutch - the go to offering is Yuasa. On the basis that Tuonos have also been known to have sprag issues, I would start there
Has thanked: 9507 times
Been thanked: 9716 times
Re: What battery?
GuzziPaul wrote: Wed Mar 09, 2022 8:52 am The Tuono failed to start yesterday morning, despite starting the night before. Left it charging all day and it it started fine last night but only showed 11.4V on the built in meter and the same this morning after charging all night.
How come a battery only lasts 2 years?
My ZX10R was 16years old when I sold it and it still had the original battery. The bike was only used in good weather,but always kept on an Optimate otherwise.
If I needed a battery now,I'd be going Lithium,or if you want old school,then Yuasa.
Has thanked: 2192 times
Been thanked: 1218 times
Re: What battery?
KungFooBob wrote: Wed Mar 09, 2022 9:03 am Cheapest.
Tayna are great - they offer good alternatives to Yuasa at a fraction of the cost. I had a high-CCA Yuasa on my Trumpet and recently replaced that with an even higher CCA alternative for about 50% of the price
Re: What battery?
Skub wrote: Wed Mar 09, 2022 10:31 am
I have a lithium on the Diavel.
It's good point
It is lighter - but on a Diavel, TBH, that is hardly a key factor
The bad points
Needs a special charger
Rubbish in the cold - I don't often take it out Dec - March but it's a big twin, needs big power - and Lithium struggles to do that when it is cold.
No idea what the longevity will be
Cannot be left an optimal as they explode - this might be a legend but ...
Re: What battery?
Mr Moofo wrote: Wed Mar 09, 2022 10:40 am
It's good point
The bad points
Here's one you can plug and leave. For Shido and other batteries.
https://www.spengineering.co.uk/shido-b ... -dc40.html
Has thanked: 4201 times
Been thanked: 2762 times
Re: What battery?
First Yuasa in my 690 lasted 5 years. 2nd was iffy after a year. Not sure what I did differently as I stored/charged them the same. I'm guessing singles/twins will bugger a slightly off battery quicker than most engines though.
Ditchfinder
Re: What battery?
My LiPo has been fine in the cold. If it's cold - turn ignition to on, leave for a couple of minutes then hit the starter. The one I had on the KTM 390 was fine too.
GuzziPaul
Re: What battery?
Post by GuzziPaul »
Dodgy sprag clutch is my concern as well, I do have it on an Optimate but not full time, it get shared out with the Guzzi which has a cheap ride on lawn mower battery that has lasted 6 years.
I went for the Motobatt having read the reviews but having this second one fail after 2 years I'm having doubts.
Has thanked: 2296 times
Been thanked: 3381 times
Re: What battery?
Last winter it looked like the battery in my Falco was duff, so I started investigating alternatves. As it turned out, it was the battery charger at fault, but I'm pretty sure the Tuono uses the same battery as the Falco. I tried a Motobatt, but found that it was fractionally taller then the Yuasa battery it was going to replace, and that compromised under-seat space (I have a Scottoiler shoe-horned into that space).
I found that a Yuasa YTZ14S had almost the same CCA as the YTX14H-BS I was using (230CCA vs. 240CCA), but was only 110mm high compared to 145mm. Perhaps the YTZ14S (or equivalent) might suit sir?
asmethurst99
Has thanked: 1024 times
Been thanked: 354 times
Re: What battery?
Post by asmethurst99 »
I just bought the cheapest one I could find on eBay for the fireplace…Tayna are 5 quid cheaper
Tricky
Has thanked: 2443 times
Been thanked: 2550 times
Re: What battery?
Post by Tricky »
Pretty much mirrors my experience with the original Yuasa on my ZX10, I reckon you can't really go wrong with one, I've had 2 Tuonos, bought a Motobatt once, then when it failed within a couple of years went Yuasa (the slightly larger 14Ah with a spacer under the securing bracket ) and never looked back.
Also had a Motobatt on my 525EXC, similar story - it seemed to crank slower and for less time than the Yuasa it replaced and it was fecked in no time relatively speaking .
They are only small (4Ah) on the off-roaders and get a hard life on a big single, I replaced it with an Enduroline 7 or 8 years ago purely as they claimed to have greater CCA than anything else and weren't a lot of money, and it's been absolutely brilliant, turns the old girl over faster than anything I've previously had on there and still going strong, and it's become my default battery of choice now for any vehicle that they make one for (apart from my little RC390 where I went Lithium as every gram counted :lol: )
- Highly recommended :thumbup:
https://www.tayna.co.uk/motorcycle-batt ... nduroline/
Re: What battery?
Tricky wrote: Thu Mar 10, 2022 10:15 am
It's an Enduroline I've just fitted to my Trumpet, it's CCA was even higher than the high-CCA Yuasa I had fitted.
