Tool purchases
Re: Tool purchases
So later, in Wickes I spotted a 3Ah Makita combi drill and thought sod it, I'll get it.Half an hour passes, two obviously returned products (one missing the supposedly included battery) and a whole load of "we can't find that one" I ended up with this:
- Has thanked: 10271 times
- Been thanked: 6887 times
Re: Tool purchases
I've got same drill. It's greatcrust wrote: ↑Sun Feb 20, 2022 10:55 am Makita.jpgStood in the pissing rain yesterday holding a mains drill on an extension lead rebuilding my fence I decided I'd get me one of the new-fangled battery jobbies.
- Has thanked: 2552 times
- Been thanked: 6257 times
Re: Tool purchases
Can't beat a bit of air power
We had loads of them in the trim shop at my old place, they make short work of carbon fibre. Too short if you're not careful!
- Has thanked: 1348 times
- Been thanked: 1722 times
Re: Tool purchases
I can sometimes remove a nail dent with a good hard file but it really depends on how hard the file or chisel is.Silly Car wrote: ↑Tue Feb 15, 2022 9:04 pm I picked up a cheap n nasty honing guide and a range of wet and dry paper from 120 through to 5000 grit
I’ve spent an enjoyable time fettling a couple of old wood chisels using a small piece of 18mm MDF from the garage as a flat plate under the wet and dry.
With the first chisel, I had to start with a 40g sanding belt to get rid of a nail divot and a slopey bevel, gradually worked through the grades up to 800grit on the primary bevel, then on the second bevel up to full 5000 grit, 10-15 strokes per grade, with the end result of a fairly polished second bevel which could shave the hair on my arm. That level of sharpness is a first for me.
Second chisel just needed 10-15 strokes per grade to re-establish a clean primary and the same to get a hair shaving edge on the second.
Just need to work my way through my other chisels and planes now
Sometimes its too hard for the file and it just skates off the surface.
I've done the same with two knives I've snapped the point off and just filed it to shape (usually with more belly to the blade) then sharpened as usual.
There's also a Hultafors knife I use for insulation when I'm unlucky enough to be doing loads of pipe boxing (using it for sound insulation) and every once in a while I just touch it up with a file and thats sharp enough for insulation.
- formula400
- Has thanked: 444 times
- Been thanked: 863 times
Re: Tool purchases
This magnetic bolt tray
- D5A93CBD-BFFA-40E2-9C30-0E6436C71E4B.jpeg (529.67 KiB) Viewed 777 times
CBR650r
- DefTrap
- Has thanked: 2265 times
- Been thanked: 2193 times
Re: Tool purchases
I'm on the verge of buying another Makita just like this, but in the end I just ended up repairing the one I already have (older model, busted the chuck).crust wrote: ↑Sun Feb 20, 2022 10:55 am Makita.jpgStood in the pissing rain yesterday holding a mains drill on an extension lead rebuilding my fence I decided I'd get me one of the new-fangled battery jobbies.
I probably -would- have bought this exact kit but all the unnecessary extras put me off.
- Has thanked: 485 times
- Been thanked: 1428 times
Re: Tool purchases
Before i moved to the LXT battery range of Makita i bought this combi set https://www.diy.com/departments/makita- ... oreId=1287crust wrote: ↑Sun Feb 20, 2022 10:55 am Makita.jpgStood in the pissing rain yesterday holding a mains drill on an extension lead rebuilding my fence I decided I'd get me one of the new-fangled battery jobbies.
The rattle gun is under 100Nm but its fantastic for rattling in larger screws you may use for any fencing work and the 1.5Ah battery's last surprisingly well. I must have got it in a sale as i was only just over £100 probably two years ago
Re: Tool purchases
Yeah, I didn't want all the extras, I wanted the kit with no extras but two batteries, however the kit with extras was in stock and the others wern't.
I'm sure I'll use the extras along the way.
- Has thanked: 6381 times
- Been thanked: 4761 times
Re: Tool purchases
LOL. Mine didn't come with those extras so I actually bought a separate Makita set.
(But I do have 3 or 4, 3 & 4.0Ah batteries ).
(And a couple of Stihl ones)
Re: Tool purchases
Needed a G-clamp to push the pistons back into a caliper. This one is all they had. It's officially shite and now is in the bin now the job is done. Took about 10 times longer than it should.
- Has thanked: 599 times
- Been thanked: 2448 times
Re: Tool purchases
Tried mole grips and everyting. These buggers were stuck, hard.MrLongbeard wrote: ↑Sat Feb 26, 2022 9:49 pmA pair of channellock pliers every time, fits everything and works
- Been thanked: 7535 times
Re: Tool purchases
If you can't push pistons in by hand, then there's an issue somewhere.
Except for rear callipers on cars, which need winding in.
Re: Tool purchases
You did remember to take the reservoir cap off didn't yaYorick wrote: ↑Sat Feb 26, 2022 9:51 pmTried mole grips and everyting. These buggers were stuck, hard.MrLongbeard wrote: ↑Sat Feb 26, 2022 9:49 pmA pair of channellock pliers every time, fits everything and works
Re: Tool purchases
Yeah, I know. It's Pen's AJP. Been back to the shop and they said it was OK. Still a problem so took it apart tonight. We're off out tmrw so had to go buy a clamp. I wound them in 3 or 4 times with WD40 helping and that might have done the jobKungFooBob wrote: ↑Sat Feb 26, 2022 9:55 pm If you can't push pistons in by hand, then there's an issue somewhere.
Re: Tool purchases
Yes dearMrLongbeard wrote: ↑Sat Feb 26, 2022 9:56 pmYou did remember to take the reservoir cap off didn't yaYorick wrote: ↑Sat Feb 26, 2022 9:51 pmTried mole grips and everyting. These buggers were stuck, hard.MrLongbeard wrote: ↑Sat Feb 26, 2022 9:49 pm
- Has thanked: 70 times
- Been thanked: 79 times
Re: Tool purchases
Purchased one of those ‘dent puller’ kits off Amazon, for the life of me I cannot get the glue to stick strong enough for it to work! Followed various FAQ fixes but to no avail.
It’s only a small dent, caused by my lads basketball hoop falling over in the wind & clouting the car door!!! Luckily it was the plastic backboard that hit the car but still.. been quoted £140+VAT to fix it!! I’m in the wrong job…. No wait….. I can’t get the glue to work
