NOCTURNAL UNICORN: A HARLEY FAT BOY, ROUGH CRAFTS STYLE
Has thanked: 5456 times
Been thanked: 13103 times
https://www.bikeexif.com/harley-fat-boy-rough-crafts
sometimes it surprises me, but a few of you like the odd Harley... so...
Has thanked: 1829 times
Been thanked: 1469 times
Re: NOCTURNAL UNICORN: A HARLEY FAT BOY, ROUGH CRAFTS STYLE
Its quite nice- if you like that sort of thing
Dickyboy
Has thanked: 485 times
Been thanked: 343 times
Post by Dickyboy »
If I were to own a harley it would be one like that, not sure where I'd put the no plate thou as side mounted plates look hideous
Been thanked: 7544 times
I was goin to say it looks just like every other Harley... then I spotted the front brakes.
Has thanked: 2636 times
Been thanked: 1523 times
Can't imagine that twin calipers on a single front disc are going to do anything but overheat the disc.
And I can't imagine it goes round corners with that tractor tyre on the front.
Has thanked: 1350 times
Been thanked: 1730 times
To me it's not significantly worse than any other Harley.
So...erm...
Naah, yer alright.
Has thanked: 9846 times
Been thanked: 10160 times
Is that a 200 section on the front?
That bus will need power steering.
I like it to look at,but I'd probably hate it to ride.
DefTrap
Has thanked: 2267 times
Been thanked: 2193 times
Post by DefTrap »
My brother had a terrible cb750 uncle bunt framed chopper that looked a bit like that. With big fat tyres. Yes handled like a pig. Sort of cool though? It was certainly fun and eye catching.
Has thanked: 2948 times
Been thanked: 1884 times
I like it, its how I'd have drawn and coloured a Harley when I was 12 (if I could draw and colour inside the lines).
The name though?
Is it a euphemism for an early morning stiffy?
Has thanked: 600 times
Been thanked: 2453 times
200/60 ain't that big, s'long as you don't square it off.
But then I'm looking at it from my stock 150 point of view, I suppose if you've got widgy 120's or less it might seem that way.
Has thanked: 2409 times
Been thanked: 3639 times
Interesting (in a detached kind of way) to look at, bet it would be an absolute pig to ride with that stupid fat front tyre, the no-travel front suspension and solid rear end.
It's an M8 softail, it ain't a rigid, the rear suspension adjuster is right there in plain daylight on the RHS
MrLongbeard wrote: Fri Feb 11, 2022 10:07 pm It's an M8 softail, it ain't a rigid, the rear suspension adjuster is right there in plain daylight on the RHS
Fair cop - I'm clueless with Harleys (as you may have gathered).
Still reckon it wouldn't be much fun to ride.
mangocrazy wrote: Fri Feb 11, 2022 10:13 pm
I don't disagree, changing it to mid control instead of leaving the forwards to make it look sportier ain't gonna be comfy.
Has thanked: 2554 times
Been thanked: 6262 times
I'm enjoying the brake callipers in an abstract "er..OK then" sort of way.
Not at all sure about the naming, either. 'Rough Crafts' is pretty close to 'Rough Trade', innit?
But then maybe that's the target market?
Where's the bumming hat when it's needed?
Mr. Dazzle wrote: Fri Feb 11, 2022 10:37 pm I'm enjoying the brake callipers in an abstract "er..OK then" sort of way.
That caused a bit of a double take here, as well...
Been thanked: 4125 times
If you've got a nocturnal unicorn would the bumming hat fit?
Le_Fromage_Grande wrote: Fri Feb 11, 2022 11:08 pm If you've got a nocturnal unicorn would the bumming hat fit?
During daytime,yes.
