Cleaning exhaust headers
Has thanked: 10282 times
Been thanked: 6894 times
Re: Cleaning exhaust headers
inewham wrote: Mon Jan 17, 2022 5:53 pm Like a big yoyo that crusty jugglers swing around on sticks
Don't you have to be scruffy and unwashed with goatee beard to use them?
Has thanked: 1264 times
Been thanked: 1188 times
Post by slowsider »
inewham wrote: Mon Jan 17, 2022 5:56 pm
Yorick wrote: Mon Jan 17, 2022 5:43 pm
inewham wrote: Mon Jan 17, 2022 5:38 pm 1 - get an old rubber diablo
A what?
ISTR you had a sex dungeon? you could probably just drill and tap a butt plug
That's for the end can.
Druid
Has thanked: 276 times
Been thanked: 900 times
Post by Druid »
From my personal experience of Triumph headers, they'll turn brown again about 90 seconds after you start the engine. Save yourself a load of grief and just hose them down to get the worst of the dirt off
Has thanked: 2561 times
Been thanked: 2293 times
Le_Fromage_Grande wrote: Mon Jan 17, 2022 4:32 pm
Cousin Jack wrote: Mon Jan 17, 2022 2:11 pm Only from Weeksy..............!
Autosol (or something similar). impregnate some strong cloth tape with it, and wrap it around and saw it too and fro. Once upon a time I used to have a source of such tape, pre-impregnated with metal polish but I very much doubt it exists today.
Did you use the yellow or the white?
Yellow, with white to finish. I think, it was a looooong time ago!
Trinity765
Has thanked: 2442 times
Been thanked: 2398 times
Post by Trinity765 »
Rounded up the bits I need to start on this job. Walked into Wemoto and the guy behind the counter knew what bike I had - I guess that's as close to feeling famous as I'm ever going to get :bblonde:
I need to remove the radiator first so that will get a good clean while I'm at it. I have some of this stuff coming GTG Condenser Cleaning Foam - has anyone used anything similar (for radiators, not headers :P ).
https://www.amazon.co.uk/gp/product/B09 ... UTF8&psc=1
Has thanked: 2636 times
Been thanked: 1523 times
Trinity765 wrote: Sat Feb 05, 2022 10:17 am Rounded up the bits I need to start on this job. Walked into Wemoto and the guy behind the counter knew what bike I had - I guess that's as close to feeling famous as I'm ever going to get :bblonde:
I'd be very cautious using that on a radiator made from aluminium. Alkalis - which is what this is said to be - corrode exposed aluminium.
Doesn't take more than a pinprick hole and the radiator's done for... I had a tiny salt corrosion hole on the Hornet's radiator a couple of years back... the first warning was a warm, wet boot on a hot summer's day.
Trinity765
The Spin Doctor wrote: Sat Feb 05, 2022 10:27 am
OK thanks - I'll hold back on it.
Trinity765
:cry:
This is why I like crochet.
Image2022-02-05_12-30-17 by Trinity 765, on Flickr
Image2022-02-05_12-41-53 by Trinity 765, on Flickr
Has thanked: 4367 times
Been thanked: 2856 times
You've got your work cut out there!!
Trinity765
Supermofo wrote: Sat Feb 05, 2022 12:41 pm You've got your work cut out there!!
:cry: :cry: :cry: :cry: :cry:
Pgm
Has thanked: 6 times
Been thanked: 83 times
Post by Pgm »
Weeksy will have a heart attack when he sees that.
Has thanked: 9849 times
Been thanked: 10163 times
Get some stainless studs and nuts while you are in there.
I'd give those header nuts a good soaking too,before trying to loosen.
Trinity765
Skub wrote: Sat Feb 05, 2022 1:55 pm Get some stainless studs and nuts while you are in there.
They are soaking now :thumbup:
I picked up my Crème Brule torch when I popped home in case things get really tough.
I was just looking at those... they're worse than the ones on my 40 year old Honda.
Has thanked: 2948 times
Been thanked: 1884 times
Trinity765 wrote: Sat Feb 05, 2022 12:33 pm :cry:
Is that a submarine exhaust system?
Trinity765
inewham wrote: Sat Feb 05, 2022 3:26 pm
Trinity765 wrote: Sat Feb 05, 2022 2:24 pm I picked up my Crème Brule torch when I popped home in case things get really tough.
If they won't shift have a dessert!
:banana-wrench:
Trinity765
How would I get the studs out? The nuts are obvious - I can see those (not taken the headers off yet).
Trinity765 wrote: Sat Feb 05, 2022 4:00 pm
Put two nuts onto the stud and tighten them together using two spanners,then use the back nut to loosen the stud.
Trinity765
Skub wrote: Sat Feb 05, 2022 4:10 pm
:thumbup: Thanks.
Has thanked: 7823 times
Been thanked: 2532 times
If you get more than 3 out complete, ie not snapped, I'll be very impressed. Best of luck! :thumbup:
