Motorbike rear wheel spinners, any good?
Has thanked: 1751 times
Been thanked: 2089 times
Re: Motorbike rear wheel spinners, any good?
How do you hold bike upright and lube at the same time. Looks dodgy to me. 😬
Has thanked: 5456 times
Been thanked: 13103 times
Engine on, 1st gear. What could possibly go wrong!
Has thanked: 10282 times
Been thanked: 6894 times
weeksy wrote: Fri Jan 28, 2022 9:50 am Engine on, 1st gear. What could possibly go wrong!
That's how I do the GSXR.
BBB
Has thanked: 294 times
Been thanked: 79 times
Post by BBB »
I remember a photo of a lady with fancy black amd purple painted nails who had done that. Her nails looked good, the rest of her fingers less so.
Has thanked: 3266 times
Been thanked: 1738 times
Big Red wrote: Fri Jan 21, 2022 7:36 pm Search ebay for item 283041326546
Winds up underneath anything solid and lifts front or rear wheel allowing you to spin them.
I use that tool for wedging my Street triple swing arm when I lube the chain.If I had a MT07 I would use it for the same purpose.
Has thanked: 1017 times
Been thanked: 1784 times
Yorick wrote: Fri Jan 28, 2022 10:07 am
I do all my bikes that have a centre stand or fit on the paddock stand like this. 1st gear, pot of oil and a paint brush.
Has thanked: 15995 times
Been thanked: 10262 times
Dodgy knees wrote: Fri Jan 28, 2022 9:43 am How do you hold bike upright and lube at the same time. Looks dodgy to me. 😬
The "puck" you can see in the middle goes under the side stand then you just turn the wheel with one hand whilst oiling the chain with the other hand. :thumbup: I suspect I will try the engine running method at some point though! :roll: :lol:
DefTrap
Has thanked: 2267 times
Been thanked: 2193 times
Post by DefTrap »
Or just get yourself a decent shaft drive bike.
You can do the proper wheelies then as well. :banana-dance:
Has thanked: 9848 times
Been thanked: 10160 times
Placing the bike on an Abba stand I turn the rear wheel by hand,lovingly and fastidiously cleaning and oiling each wonderfully created link.
It's only right. 8-)
Has thanked: 7822 times
Been thanked: 2532 times
Skub wrote: Fri Jan 28, 2022 12:44 pm Placing the bike on an Abba stand I turn the rear wheel by hand,lovingly and fastidiously cleaning and oiling each wonderfully created link.
Oi weeksy, you used the wrong login.
Taipan wrote: Fri Jan 28, 2022 12:21 pm
I think with these rollers it would be safer to turn wheel by hand as you say. Running in first could be risky, if say it went out of line or summot. Paddock stand running in first is fine. And only a daft bugger would wrap his hand in the rear sprocket. 👍
Has thanked: 1264 times
Been thanked: 1188 times
Post by slowsider »
Taipan wrote: Fri Jan 28, 2022 9:35 am Bought one from Busters/M&P snd it arrived 2 days later. Good heavy bit of kit and not flimsy as expected. I’ll give it a try over the weekend.
upload pic
The remote control should make it easier :thumbup:
slowsider wrote: Fri Jan 28, 2022 3:41 pm
upload pic
I can watch Moto GP on my digital dash! :thumbup:
Has thanked: 2554 times
Been thanked: 6262 times
If you do it in 6th it'll take less time :thumbsup:
I tried it out today. First fault it moves when you try and roll the bike onto it. This was on decking, but I assume concrete will be worse. The get round is to stand behind the bike with your feet or foot against the stand and pull the bike onto it. Easy enough on a light bike like Mine but wouldn’t want to do it with anything much heavier tbh.
Moving onto oiling the chain; I used a squirty can but think puring out of a bottle with a outer would be better. I found turning the wheel with your left hand whilst putting the oil onto the chain as it rotates on the rear sprocket is best. Turning it with a spray lubricate would probably be the best solution and may knock the rating up a point?
I’m summary, centre staNd get the gold, paddock stand silver and this is an also ran! It’ll do what I want, which is saving me get the paddock stand from the shed and bringing it round the front and I suspect it’ll get hetter as I get used to using it, but I can only give it 3/5.
A trolley jack under the swinging arm or exhaust will do the job :)
Has thanked: 6382 times
Been thanked: 4771 times
Glue some rubber under it?
Yorick wrote: Sun Jan 30, 2022 1:16 pm A trolley jack under the swinging arm or exhaust will do the job :)
Again, that's something I'd have to go and get,whereas this will live under the hedge in the front garden, so I can just use it easily.
Maybe if the roller was permanently fixed somewhere handy,then it would be less of a faff?
