Motorbike rear wheel spinners, any good?
Has thanked: 15995 times
Been thanked: 10262 times
Does anyone use a rear wheel spinner? I used to have one of those adjustable big ball bearing types which was just about okay to use for lubing chain etc. As the MT doesn't have a center stand I could do with having another and note they are a roller affair now. Anyone got one? Any good?
https://www.ebay.co.uk/itm/353316772380 ... 1438.l2649
Has thanked: 1751 times
Been thanked: 2089 times
Re: Motorbike rear wheel spinners, any good?
Paddock stand ?
Has thanked: 5456 times
Been thanked: 13103 times
Terrifying to ask, but can't you fit a center stand from a Tracer?
Tricky
Has thanked: 2568 times
Been thanked: 2681 times
Post by Tricky »
I've had one for years, similar to that one only made of aluminum and knurled, I bought it to take on tours to be able to lube the chain single-handed, seemed a good idea at the time but ended up holding it on the sidestand while someone else squirted as it was easier so have never really used it.
That's the only reason I can think for having one, a paddock stand or centre stand ( or a helper to tilt whilst you squirt or vice-versa :) ) is infinitely preferable IMO
( And mine is a bit more Gucci than the one you linked to - looks like this 8-) ;) )
Dodgy knees wrote: Fri Jan 21, 2022 8:54 am Paddock stand ?
Yes, that would be the normal choice, but that means going to the shed, bringing it round the front, hooking the bike up on it and then putting it all back. Whereas if I had one of these hidden under the hedge out the front with the chain oil, it'd be much more convenient, and likely to get done more often, iyswim?
weeksy wrote: Fri Jan 21, 2022 8:55 am Terrifying to ask, but can't you fit a center stand from a Tracer?
*plonk*! :x
Been thanked: 7544 times
If I don't have a centre stand, I tilt the bike over on the side stand (like you do when you're spinning the bike around) and wedge something under the swingarm (like an axel stand) to keep the rear wheel off the floor, simples.
Has thanked: 10282 times
Been thanked: 6894 times
All the MotoGP teams have one. You might be as cool as them :)
Monstyr
Has thanked: 9 times
Been thanked: 94 times
Post by Monstyr »
Get yourself an abba stand, they have adaptors to fit most bikes and is one of the most useful accessory/tools I’ve ever bought.
McNab
Has thanked: 131 times
Been thanked: 178 times
Post by McNab »
Taipan wrote: Fri Jan 21, 2022 8:18 am Does anyone use a rear wheel spinner? I used to have one of those adjustable big ball bearing types which was just about okay to use for lubing chain etc. As the MT doesn't have a center stand I could do with having another and note they are a roller affair now. Anyone got one? Any good?
I had one of those. I didn't really like it as when I turned the wheel it kept slipping out to the edge and then getting stuck. Only years later, the last time I saw a thread on these, did I realise what the black rubber puck thing was for :D
Has thanked: 1017 times
Been thanked: 1784 times
Oil the bits you can see, move it a foot, oil the rest. Everything else seems unnecessarily complicated compared to that.
Has thanked: 600 times
Been thanked: 2453 times
FFS, I read the thread title and thought you'd gotton cool again
Deep deep disappoints
asmethurst99
Has thanked: 1043 times
Been thanked: 362 times
Post by asmethurst99 »
Wedge against the bobbin for the paddock stand? Lol
That's the method I was trying to describe.
My 'rents garage had some bolts he'd made to lock the up and over door to the floor, they were the perfect length for wedging under the Blade swingarm.
asmethurst99
There was a motrax gadget called a stand stick.I had one for my srx in 95 .
Big Red
Has thanked: 3 times
Been thanked: 73 times
Post by Big Red »
Search ebay for item 283041326546
Winds up underneath anything solid and lifts front or rear wheel allowing you to spin them.
Big Red wrote: Fri Jan 21, 2022 7:36 pm Search ebay for item 283041326546
https://www.ebay.co.uk/itm/283041326546
Has thanked: 2636 times
Been thanked: 1523 times
asmethurst99 wrote: Fri Jan 21, 2022 5:58 pm
Or a handy length of dowel cut to the right length. Cost nothing.
Bought one from Busters/M&P snd it arrived 2 days later. Good heavy bit of kit and not flimsy as expected. I’ll give it a try over the weekend.
upload pic
