Kitchen Knife Repair
It’s a bit of a slow period in the workshop so time to dip in to the project box. (Some might remember the previous knife scale repair on the other site.)
This is an M&S serrated kitchen knife which was particularly useful for shredding lettuce and cabbage etc.
It has broken its back and had a fairly ineffective temporary repair and I wasn’t sure if it would be repairable or end up in the bin. I do have some loveless bolts in stock and a piece of purpleheart wood that Mr demographic kindly sent down.
With the handle removed, it’s fairly obvious why it has failed – the tang really needs extending. I have some 316 stainless mig wire in stock but unfortunately no stainless sheet.
- K2.jpg (340.37 KiB) Viewed 1294 times
- K1.jpg (310.02 KiB) Viewed 1294 times
- Felix
- Has thanked: 717 times
- Been thanked: 2045 times
Re: Kitchen Knife Repair
I would drill a hole in knife tang and counter sink a nut n bolt through handle. Fill countersink with resin for the likes for the sake of hygiene.
Sorry for the delay here, my posts have to be approved by a moderator.
Anyway,this is hard and blunted a couple of bits trying to drill a hole so resorted to the blacksmiths' technique of heating to red hot and using a tapered punch.
- K3.jpg (337.58 KiB) Viewed 1215 times
After a bit of googling, I took a gamble and used the ordinary mild steel mig wire and gas for the puddle welds. The penetration wasn't great so ground off the welds flat and welded from the other side as well.
- K5.jpg (398.86 KiB) Viewed 1211 times
Today's installment.
I didn't think this deserved the purpleheart so used a piece of oak instead. The handle thickness was originally 16mm so ran the oak through the thicknesser to 8mm, that allows .5mm on each side for sanding.
- K6.jpg (361.58 KiB) Viewed 1177 times
- K7.jpg (369.73 KiB) Viewed 1177 times
- Has thanked: 6125 times
- Been thanked: 15511 times
Thanks Weeksy, I know what you mean, it's a good job I don't charge by the hour.
I've always enjoyed making and repairing things so this comes under recreation for me.
Over the weekend, I applied some stain and a couple of coats of Danish oil.
Mrs XT's verdict - 'It looks a bit artificial but should look better after a few washes'. There's gratitude for you.
- K10.jpg (303.5 KiB) Viewed 1112 times
- Has thanked: 780 times
- Been thanked: 3224 times
Aren't corby bolts a tad OTT for a pretty basic kitchen knife?
Good work though, it looks good
Thanks.MrLongbeard wrote: Mon Jan 24, 2022 11:10 am Aren't corby bolts a tad OTT for a pretty basic kitchen knife?
I had some loveless bolts left over from the first knife scale project which I detailed on the previous shed. This is what that one looks like today.
It'll be interesting to try corby bolts. Shopping time...
- Sabatier1.jpg (347.31 KiB) Viewed 1071 times
You need to watch more;iansoady wrote: Tue Jan 25, 2022 2:21 pm I have to confess I've never heard of either loveless bolts or corby rivets. Thanks for expanding my knowledge!
Forged in Fire
Alec Steele (youtube)
Will Stelter (youtube)
Walter Sorrells (youtube)
And then moan at the wife that you've nowhere to set up a little brake drum forge
