Arse buckets: New rear shock needed
Has thanked: 1829 times
Been thanked: 1469 times
According to TF tuned my Cane Creek DB is fucked - the air canister shows signs of wear etc ...
New air canisters are available - maybe the end of this year!
So multi adjustable at every level - but made of cheese :evil:
I need a 190 x45 rear shock - as bulletproof as possible. Suggestions please...
Has thanked: 5452 times
Been thanked: 13097 times
Re: Arse buckets: New rear shock needed
Oh arse.
Since going coul I've been happy, less to go wrong I think.
Mine is the Marzochi Bomber CR if that helps.
Has thanked: 2945 times
Been thanked: 1883 times
Bummer, my Enduro used to eat its CC inline, despite it having the modified internals. The Fox X2 isn't much better, I don't think the shocks like the side loads the trunnion mount places on them. Sorry, not much help.
Had a long chat with a guy at TF Tuned. Good thing was he thought it was a rocket shock - so 200 x 50 , not a 190x45 - that means he does have a new air can , so all is good.
But he did say that Cotic Rockets are going though air cans at a rapid rate - so hence the stock issue.
Also talked to Cotic - who said that coils cannot be used with Cotic frames ( or rather shouldn't be).
They suggest Fox DPX or a RockShox DLX
(TF Tuned were not flattering about RS rear units)
So it appears that it hasn't failed this time ....
Why no coils?
Good news it can be sorted. Getting back tomorrow?
lostboy
Has thanked: 2156 times
Been thanked: 426 times
Post by lostboy »
weeksy wrote: Thu Jan 13, 2022 5:06 pm Why no coils?
I suspect it's to do with not being able to get the rising rate required unless you buy a rising rate spring!! Most have a linear spring and the frame will probably designed with the ramp up of the air shock in mind.
lostboy wrote: Thu Jan 13, 2022 5:09 pm
Yeah I hear you. I do wonder how many of us in the real world would even notice or care at our skill. Assuming both were set up correctly, would we, hmmm
Nope - wasn't even looking like it was being repaired at 14.00 today
So Saturday, I will be on the Production Privee ...
