Not my thing.
Motorcycling photos you just like
- Has thanked: 5456 times
- Been thanked: 13103 times
- Has thanked: 1751 times
- Been thanked: 2089 times
- Been thanked: 4125 times
Re: Motorcycling photos you just like
If it's a works bike it'll get a new one every day.
I always ran my off road bikes with non o ring chains and no lubrication (I just cleaned them), the chains lasted longer that way, if you lube them the sand sticks to the oil and makes a really nice grinding paste.
Best I found was a chain oiler filled with thin oil wound up to max, the oil dripping off the chain cleaned it as you went along.
- Has thanked: 10282 times
- Been thanked: 6894 times
- Been thanked: 7545 times
- Has thanked: 6203 times
- Been thanked: 5091 times
See? It's what the experts have been saying for years.
Shafties can't wheelie.
Try, it all goes horribly wrong.
- Has thanked: 4369 times
- Been thanked: 2856 times
My mates bike shop had a big poster of this and I always liked the picture.
- Has thanked: 2409 times
- Been thanked: 3639 times
Ouch. That would have hurt. And would have been expensive...
- Bigyin
- Has thanked: 1413 times
- Been thanked: 2680 times
Bit extreme just to emulate your hero
I do think this pic speaks a lot about the 500 2 stroke era
The first two bikes I owned had enclosed chain cases, which were a bit of a double-edged sword. The chain and sprox certainly lasted longer being enclosed, but there was a great temptation to just forget about the chain until horrible noises started emanating from within.
Wouldn't it be possible to make a modern hi-tech version of a chain enclosure, or would the weight penalty not justify it?
- Has thanked: 1058 times
- Been thanked: 864 times
Is it me, or does that look more like photoshop more than a real photo?
Dunno, but it's rubbish from the composition PoV, IMHartyO
- Has thanked: 1350 times
- Been thanked: 1730 times
Macau GP.
Mamola Bronco.
I was looking for a Joey Dunlop early morning gritty practice photo with a haze of blue twostroke smoke but my Google Foo (well Duck Duck Go actually) failed me.
Some old knacker showing us that they still got it.
Mamola Bronco.
- Has thanked: 9849 times
- Been thanked: 10166 times
This the one?demographic wrote: ↑Sat Jan 15, 2022 7:21 pm
Close enough. Thanks.Skub wrote: ↑Sat Jan 15, 2022 7:38 pmThis the one?demographic wrote: ↑Sat Jan 15, 2022 7:21 pm
- Has thanked: 2556 times
- Been thanked: 6263 times
Maybe use a solid chain and a couple of gears, since you're enclosing itmangocrazy wrote: ↑Fri Jan 14, 2022 1:29 pm Wouldn't it be possible to make a modern hi-tech version of a chain enclosure, or would the weight penalty not justify it?
You mean a shaft drive, then...Mr. Dazzle wrote: ↑Sat Jan 15, 2022 10:46 pmMaybe use a solid chain and a couple of gears, since you're enclosing itmangocrazy wrote: ↑Fri Jan 14, 2022 1:29 pm Wouldn't it be possible to make a modern hi-tech version of a chain enclosure, or would the weight penalty not justify it?
