Cheers, I got 2 x 5ft 60w for the garage and amazed how much light they kick out.
LED lights for a shed
- Has thanked: 1295 times
- Been thanked: 872 times
Re: LED lights for a shed
- Bigyin
- Has thanked: 1412 times
- Been thanked: 2680 times
Couldn’t find any rating on it but it’s a 3 foot long one and gives loads of light in my little shed
- formula400
- Has thanked: 444 times
- Been thanked: 863 times
Bloody hell, so you got 1 3ft in you shed?
Guess I don’t need 2x 6ft
CBR650r
- Bigyin
There are some shadows low down if i am messing with the bikes but if i had more room i would have 1 over a work bench and one above the bikes as you said but maybe 6 foot is a bit much. The output of modern LED is about 3-4 times the old tubes. I have a much smaller shed that has old lighting and that is 2 X 4 foot tubes ...... the new little one puts out more than the 2 old ones combinedformula400 wrote: ↑Thu Jan 06, 2022 9:58 pm
The big shed i used to have had 2 X 3 foot on the ceiling, 1 at each end and a small one on a side wall but that was a 12 X 9 foot long shed ... the new place has a much smaller shed
Half the old shed
Other Half
New one
- formula400
How bigs the space your keeping warm???MrLongbeard wrote: ↑Sun Jan 02, 2022 8:47 pm2020-12-21_01-43-51 by MrLongbeard, on Flickrformula400 wrote: ↑Sun Jan 02, 2022 5:16 pm Also any recommendations on a good tubalar heater to keep the chill at bay.
5 foot, 300 watt, costs about a quid a day to run, from https://www.wearetubularheaters.co.uk/s ... with-plug/
Don't expect them to warm the space up unless you're going to get 4 of 'em, but just that one keeps the damp at bay for me.
CBR650r
- Has thanked: 600 times
- Been thanked: 2451 times
- Has thanked: 1264 times
- Been thanked: 1188 times
- formula400
So got the lights fitted yesterday, got 2 x 4ft, plenty of light and not too harsh. Well pleased.
https://www.screwfix.com/p/lap-twin-4ft ... 00lm/6481v
Next week, I’ve got a sparky coming to get power from the house to the shed.
- 2F118F0F-505B-46CE-93DF-247B9CD33052.jpeg (663.01 KiB) Viewed 568 times
CBR650r
- Has thanked: 6382 times
- Been thanked: 4764 times
Slight variation on a theme (and while the Screwfix sale was on ) just replaced all the old 'neon' lights under the cupboard units in the office/workroom with LED lighting and fitted them under the cupboards in the kitchen too. Cheap as chips and absolutely easy peasy...unless I want them all to come on from one switch in the kitchen. It would have been easier if the cheapskates that had the kitchen fitted had put some lighting under the units to start with so I could reuse the wiring. Hey ho, I have 'flexible illumination'
- Has thanked: 7821 times
- Been thanked: 2531 times
MrLongbeard wrote: ↑Sun Jan 02, 2022 8:43 pm I've got 2 55W LED Tri-Proof Light - 6ft (1800mm) Length - IP65 - 5000K in a standard sized garage and they put out more than enough light.
Similar to https://www.novelenergylighting.com/lum ... 55ksf.html so I imagine 2 is plenty for wee shed.
If not just make sure you get ones which are daisey chainable so you've only got to run a new wire from one light to the next if you want to add more
How can you tell which ones are daisy-chainable from the spec-sheets?? (eg on screwfix website)
FWIW - your image, copied from Facebook, is no longer viewable.
No idea, the ones I looked at and got specified it on the info sheet, others look like they do too;Rockburner wrote: ↑Thu Feb 10, 2022 2:54 pm How can you tell which ones are daisy-chainable from the spec-sheets?? (eg on screwfix website)
https://www.lyco.co.uk/eterna-eco-48w-c ... n-5ft.html
If it ain't mentioned maybe fire them a message and ask.
The photo was nothing special;
166376094_10158247242299397_6506211411235011963_n by MrLongbeard, on Flickr
Some of them say 'linkable' in the product description. Eg LAP batten product code 8373B. My LAP ones each came with a connector. Doesn't mean that the ones that don't say it aren't but if you go for the ones that do you're safe. (If the ones you do get haven't got the connector included, I've got at least 3 spare ).Rockburner wrote: ↑Thu Feb 10, 2022 2:54 pmMrLongbeard wrote: ↑Sun Jan 02, 2022 8:43 pm I've got 2 55W LED Tri-Proof Light - 6ft (1800mm) Length - IP65 - 5000K in a standard sized garage and they put out more than enough light.
Oh and in the product spec it says cable entry left and right.
- Has thanked: 486 times
- Been thanked: 1430 times
Forgot about this but i ordered one of these for my attic. Great light for little money but i think for the attic i need a 2nd one so just got round to ordering it now. I presume if you piggy back one from the other you dont notice any light loss.formula400 wrote: ↑Sat Jan 15, 2022 8:32 am So got the lights fitted yesterday, got 2 x 4ft, plenty of light and not too harsh. Well pleased.
- formula400
Yeah the 2nd is piggy backing off the first. Seems to be no light lost at all.
CBR650r
