LED lights for a shed
- formula400
- Has thanked: 444 times
- Been thanked: 863 times
Right, currently looking at lighting options for the shed.
What’s good??? It’s 15x5ft
I want to be able to work/see in there, it has minimal natural light.
So……. What are my options? It’s hooked up to the mains
Also any recommendations on a good tubalar heater to keep the chill at bay.
CBR650r
- formula400
- Has thanked: 9825 times
- Been thanked: 10145 times
Re: LED lights for a shed
I have two led striplights in the garage,they are very bright,much better than the old fluorescent that used to be there.
- formula400
Similar or the same as these in your link.
https://www.tlc-direct.co.uk/Products/GLPRCLED.html
- DefTrap
- Has thanked: 2260 times
- Been thanked: 2191 times
I have loads of led striplights. They're cheap as chips and if you have a few with simple plugs then they make cheap 'work lights' for decorating etc
- formula400
Would I have 2 running the length of the shed or what??? A few going across?Skub wrote: ↑Sun Jan 02, 2022 5:46 pmSimilar or the same as these in your link.
Is there a calculation to work out how many per square foot?
CBR650r
- Has thanked: 599 times
- Been thanked: 2442 times
I've got 2 55W LED Tri-Proof Light - 6ft (1800mm) Length - IP65 - 5000K in a standard sized garage and they put out more than enough light.
Similar to https://www.novelenergylighting.com/lum ... 55ksf.html so I imagine 2 is plenty for wee shed.
If not just make sure you get ones which are daisey chainable so you've only got to run a new wire from one light to the next if you want to add more
2020-12-21_01-43-51 by MrLongbeard, on Flickrformula400 wrote: ↑Sun Jan 02, 2022 5:16 pm Also any recommendations on a good tubalar heater to keep the chill at bay.
5 foot, 300 watt, costs about a quid a day to run, from https://www.wearetubularheaters.co.uk/s ... with-plug/
Don't expect them to warm the space up unless you're going to get 4 of 'em, but just that one keeps the damp at bay for me.
- Has thanked: 836 times
- Been thanked: 1238 times
I have a 20W LED strip light either side at the front of my double garage, I find them plenty bright enough to work in the middle with power tools. Having two is probably more important than ultra bright so you don't get much shade where your are working.
I say 20W but I'm doubting that now as my fittings look exactly the same s MrLongbeard's.
- Has thanked: 7817 times
- Been thanked: 2527 times
- Has thanked: 218 times
- Been thanked: 689 times
MrLongbeard wrote: ↑Sun Jan 02, 2022 8:43 pm I've got 2 55W LED Tri-Proof Light - 6ft (1800mm) Length - IP65 - 5000K in a standard sized garage and they put out more than enough light.
You didnt use a spirit level when you built the garage, then?
- formula400
Brilliant, not needed for warmth but like you, just incaseMrLongbeard wrote: ↑Sun Jan 02, 2022 8:47 pm2020-12-21_01-43-51 by MrLongbeard, on Flickrformula400 wrote: ↑Sun Jan 02, 2022 5:16 pm Also any recommendations on a good tubalar heater to keep the chill at bay.
CBR650r
You'll need to be mindful where you mount it / them, they get bloody hot to the touch so you don't want to be brushing against it or have stuff hanging / draped over or to close aboveformula400 wrote: ↑Mon Jan 03, 2022 11:16 am
- Has thanked: 484 times
- Been thanked: 1427 times
If anyone got in to nick your bike would taking the wheel off not render that chain useless as it looks like it could be dropped out and wheel put back on? Being a garage i dare say you will supply the tools also.
It's a possibility, however I have stacked the deck in my favour;
1, No I wouldn't supply the tools as I don't have an imperial socket big enough to fit the spindle yet.
2, They'd also have to remove the fender, it is solid steel not plastic, but they could use my tools for that
3, They'd have to man handle a 300+ kg bike about to do it
4, I live in a low crime area
5, All 3 of my neighbours are retired and there always at last one of them in
6, 2 of 'em have outside cameras
7, If I'm away for a day or 3 there's another chain on the back wheel
8, It's alarmed
9, There's a Honda Civic parked in front of the door
10, I have a noisy gravel driveway
You pay's your money and take's your chances, and I reckon my solution is better than a small chain that would fit through the frame.
Out of all of worries that we face on a daily basis, running out of beer gets more thinking time than being concerned my bike is going walkies
- formula400
MrLongbeard wrote: ↑Mon Jan 03, 2022 11:52 amYou'll need to be mindful where you mount it / them, they get bloody hot to the touch so you don't want to be brushing against it or have stuff hanging / draped over or to close aboveformula400 wrote: ↑Mon Jan 03, 2022 11:16 am
Good to know, I assumed they would get to hot. I’ll have to have a think as it’s quite small abs sod it burning down
CBR650r
- Bigyin
- Has thanked: 1412 times
- Been thanked: 2680 times
I have a single one similar to the ones you linked and its sufficient for my 12 X 8 foot shed. As others have said the new LEDs put out a lot more light than old fashioned strip lightsformula400 wrote: ↑Sun Jan 02, 2022 5:16 pm Right, currently looking at lighting options for the shed.
If i remember i'll have a look tomorrow for the rating on it
- formula400
Bigyin wrote: ↑Wed Jan 05, 2022 8:59 pmI have a single one similar to the ones you linked and its sufficient for my 12 X 8 foot shed. As others have said the new LEDs put out a lot more light than old fashioned strip lightsformula400 wrote: ↑Sun Jan 02, 2022 5:16 pm Right, currently looking at lighting options for the shed.
Been having a look, screw fix do some Decent ones, so potentially going with a small 2/3ft one at the back over the work bench and a 5/6ft going down the centre of the shed
CBR650r
