Electricals question
- Has thanked: 6376 times
- Been thanked: 4753 times
Just bought a new panel heater (Creda) to replace the rubbish, broken Levante that the electrician fitted when he wired up the man-cabin.
Q? If I buy a free-standing one, almost identical, it comes fitted with a 3-pin plug. Buy a wall-mounted one and, according to all the info, it must be wired into a fused spur thingummybob.
Wossat all about?
(It's not a problem as the original is wired to a fused spur thingummybob, just puzzled).
Ta!
Wossat all about?
Ta!
- Been thanked: 4124 times
Re: Electricals question
You can stick a plug on it, it will work, it won't catch fire, but it won't meet electrical safety regulations.
True. The Screwfix support people on-line don't say as much but it's pretty clear that people do. Just wondered why the regs are so odd.Le_Fromage_Grande wrote: ↑Tue Dec 14, 2021 2:43 pm You can stick a plug on it, it will work, it won't catch fire, but it won't meet electrical safety regulations.
I think it's a bathroom thing, so you don't unplug it with wet hands.Count Steer wrote: ↑Tue Dec 14, 2021 2:49 pmTrue. The Screwfix support people on-line don't say as much but it's pretty clear that people do. Just wondered why the regs are so odd.Le_Fromage_Grande wrote: ↑Tue Dec 14, 2021 2:43 pm You can stick a plug on it, it will work, it won't catch fire, but it won't meet electrical safety regulations.
In which case I'm tempted to put a plug on it....but the spur is closer than the socket, so spur it is. (Probably need to be Part P just to do that!).Le_Fromage_Grande wrote: ↑Tue Dec 14, 2021 2:56 pmI think it's a bathroom thing, so you don't unplug it with wet hands.Count Steer wrote: ↑Tue Dec 14, 2021 2:49 pmTrue. The Screwfix support people on-line don't say as much but it's pretty clear that people do. Just wondered why the regs are so odd.Le_Fromage_Grande wrote: ↑Tue Dec 14, 2021 2:43 pm You can stick a plug on it, it will work, it won't catch fire, but it won't meet electrical safety regulations.
I think you're okay to connect to a fused spur, but ask Couchy, he's an electrician.Count Steer wrote: ↑Tue Dec 14, 2021 3:01 pmIn which case I'm tempted to put a plug on it....but the spur is closer than the socket, so spur it is. (Probably need to be Part P just to do that!).Le_Fromage_Grande wrote: ↑Tue Dec 14, 2021 2:56 pmI think it's a bathroom thing, so you don't unplug it with wet hands.Count Steer wrote: ↑Tue Dec 14, 2021 2:49 pm
- Has thanked: 65 times
- Been thanked: 1235 times
Didn't the original levante fitting get tested?
Shove it in with some matchsticks, what could go wrong?
- Has thanked: 836 times
- Been thanked: 1238 times
Oh, sure it was tested and worked fine for a year+ then the digital controller went on the fritz. Usual thing, make something more complicated and introduce more potential points of failure.
Matchsticks? Nah, I'll stick a bayonet plug on the end and run it from a light bulb socket.
(No drilling involved, it's a wooden structure with all the electrics run internally in conduit).
(Mussels - Titan SDS. Had one, did the job I needed it for. Sold it to the landscaper, he broke it ).
- Has thanked: 326 times
- Been thanked: 2173 times
The free standing one is a portable appliance so you can move it round hence it needs a plug, the wall mounting one is a fixed appliance so needs hard wiring in through a fused spur. Both need a fuse to protect them one has it in the plug the other has it in the spur.Count Steer wrote: ↑Tue Dec 14, 2021 2:42 pm Just bought a new panel heater (Creda) to replace the rubbish, broken Levante that the electrician fitted when he wired up the man-cabin.
Wossat all about?
Ta!
But if you put a plug on the wall mount one it’ll work just fine and be safe
'Tis done and working
Slightly smaller and lower power than the old one but it's mainly for background heat and frost protection (got a greenhouse type fan blower for additional heat when I'm working in there).
I even got to use my super-duper wire strippers that I bought for a project that involved making about 500 plastic tubes with LED strips in.
- Has thanked: 484 times
- Been thanked: 1427 times
Because sparks like to suck air between there teeth just before fleecing you out a fortnights wage for dare calling them out to do some work.Count Steer wrote: ↑Tue Dec 14, 2021 2:49 pm [
Meh it’s domestic, any spark worth their weight wouldn’t touch domestic, all you’ll get is boil in the bag one man bands. Even then the average homeowner assumes the van and tools are free issue, materials are nicked and the VAT will be knocked off for cash mate. All that is best left to the domestic sparkiesFelix wrote: ↑Wed Dec 15, 2021 11:35 pmBecause sparks like to suck air between there teeth just before fleecing you out a fortnights wage for dare calling them out to do some work.Count Steer wrote: ↑Tue Dec 14, 2021 2:49 pm [
- Has thanked: 2551 times
- Been thanked: 6245 times
The regs don't strike me as odd?
They're just saying you have to have a fuse right? Or have I overlooked something?
Err. The bloke that wired our cabin was tiptop. Sure, a one-man band but he picked up a lot of work from the cabin company.Couchy wrote: ↑Thu Dec 16, 2021 2:20 pmMeh it’s domestic, any spark worth their weight wouldn’t touch domestic, all you’ll get is boil in the bag one man bands. Even then the average homeowner assumes the van and tools are free issue, materials are nicked and the VAT will be knocked off for cash mate. All that is best left to the domestic sparkiesFelix wrote: ↑Wed Dec 15, 2021 11:35 pmBecause sparks like to suck air between there teeth just before fleecing you out a fortnights wage for dare calling them out to do some work.Count Steer wrote: ↑Tue Dec 14, 2021 2:49 pm [
He was wiring inside the cabin while they nail-gunned the tiles on, went all Jungle Jim getting the armoured cable from the house and down the garden, put a new consumer unit in and wriggled his way around the loft with the new, bigger diameter earth - I helped feed the wire Tested everything etc etc. Never stopped, never complained...but I can see why some sparkies don't want to do it.
It appears you aren't supposed to put a fused 3-pin plug on a wall mounted heater. Obvs you have to on a free-standing one. Possibly because it might be installed in a bathroom (where there shouldn't be any sockets other than shaver but can be a fused spur).Mr. Dazzle wrote: ↑Thu Dec 16, 2021 3:13 pm The regs don't strike me as odd?
Clearly, if it's not in a bathroom, it's as safe, if not safer than a free-standing one (can't get knocked over) even if plugged rather than wired. So the rule seems to be to prevent one very specific instance...mine's in a wooden cabin with no water supply - but there's a double socket on the outside wall which is weatherproof so I can plug stuff in and use electricals in the rain
So, in summary, rules appear to replace sense, sometimes but not always. Why not just say that wall mounted heaters must be wired into a fused spur IF installed in xyz?
- Cousin Jack
- Been thanked: 2286 times
Regulations have to get tougher so sparkies can tell you it doesn't meet the new standard.
The difference is in fixed appliance or portable appliance. One is part of the electrical installation the other isn’t. The regs for the electrical installation are different to the regs for portable appliances. It’s not hard to understand
You don’t apply regs retrospectively so any work on a property to test it should be carried out to the regs in place when it was installed. Problem is you get a lot of sparks in the domestic arena saying you need a new fuse board as the regs have changed. It’s bollox but it is ised as an excuse to try and generate work. Another reason we don’t do domestic and we don’t employ sparks from the domestic world as they don’t have the knowledge or experience for anything other than house bashing.Cousin Jack wrote: ↑Thu Dec 16, 2021 5:32 pm Regulations have to get tougher so sparkies can tell you it doesn't meet the new standard.
