Pulleys, cleats and ropes - climbers / sailors / bdsm-ers
- Has thanked: 146 times
- Been thanked: 498 times
I am looking to hoist my various ladders up against the garage roof joists / ceiling and wondered if anyone could point me in the right direction.
Ideally, I’m seeking a self locking/latching solution which can be remotely latched/unlatched/ mounted within reach. Rough arse diagram below:
[attachment=0]E0F88907-DF3D-427E-B95B-55BD86C303F5.jpeg[/attachment]
I’m suspecting the simplest solution of two ceiling mounted pulleys and a simple cleat screwed to the wall will be the way to go but thought I’d check with the intelligentsia here first
- E0F88907-DF3D-427E-B95B-55BD86C303F5.jpeg (114.67 KiB) Viewed 1317 times
- Has thanked: 1264 times
- Been thanked: 1188 times
Re: Pulleys, cleats and ropes - climbers / sailors / bdsm-ers
Lidl occasionally have bicycle storage sets which might suit your purposes.
Like this: https://www.ebay.ie/itm/263838636986?ha ... 3838636986
- Mr Moofo
- Has thanked: 1829 times
- Been thanked: 1469 times
so you want a cleat? Any boat chandlers
Thanks, I think the cycle ones would be too lightweight to handle ladders hanging over the cars unless I could find a means to support the ladders at both ends while in situ.
I have found this
but can seem to find any further information.
I have found this
- Has thanked: 6382 times
- Been thanked: 4763 times
Amazon has one for ladders, bikes, canoes good for 30kg. Some moans about delivery though but you could easily make one if you got the bits.
https://www.amazon.co.uk/Ladder-Ceiling ... 6&psc=1
LOL. I'm slower than Slowsider.
- Has thanked: 2552 times
- Been thanked: 6260 times
Quite impressed by your 90ft tall garage if I'm honest.
Those amazon links are literally just pulleys and cleats in convenient kit form right?
- Mr Moofo
2.7mMr. Dazzle wrote: ↑Wed Nov 24, 2021 2:48 pm Quite impressed by your 90ft tall garage if I'm honest.
- GuzziPaul
- Has thanked: 59 times
- Been thanked: 195 times
The angle you have your first pulley will tend to pull the ladders backwards off your pivot point. You need to be pulling straight up rather than backwards. You could just use a long ratchet strap, mounting the ratchet at shoulder height, making your own wide pulleys from broom handle and plastic pipe.
- Cousin Jack
- Has thanked: 2555 times
- Been thanked: 2290 times
The pin on the diagram, if used between the top and 2nd rung, should stop the ladder slipping forward or backward more than a few inches.GuzziPaul wrote: ↑Wed Nov 24, 2021 9:35 pm The angle you have your first pulley will tend to pull the ladders backwards off your pivot point. You need to be pulling straight up rather than backwards. You could just use a long ratchet strap, mounting the ratchet at shoulder height, making your own wide pulleys from broom handle and plastic pipe.
- GuzziPaul
But how do you get the ladder over the pin to install or remove the ladder? I have a length of thick ratchet strap webbing at the far end of the garage. I slide my ladders into it and through by a couple of feet which supports the entire ladder at an angle, I can then stand on my garage stool and slide the other end into a similar arrangement it the foot end by slide the ladders back.
- Has thanked: 16232 times
- Been thanked: 3931 times
Loving that you added BDSM-ers into the title
- Has thanked: 218 times
- Been thanked: 689 times
If we can squeeze sexy sheep in, its a very short walk to BDSM...(third door on the right).
- Has thanked: 7821 times
- Been thanked: 2531 times
Maybe it's just a hook?
(a hook would also solve the issue of the ladder moving around whilst SillyCar is yo-ho-ho-ing away.)
