MCN : LiteLok take lightweight motorbike security to the next level
Has thanked: 5457 times
Been thanked: 13103 times
https://www.motorcyclenews.com/news/new ... -security/
Lightweight motorcycle security specialists LiteLok have unveiled their latest product, the Core Moto. Rather than aiming to be impervious to attack, the LiteLok is intended to be as secure as possible while also being convenient to carry.
The new Core Moto uses a Boaflexicore Plus strap with multiple layered protection, braided outer sleeve, plant-based polymer shock absorbent layer, hardened aerospace grade steel exoskeleton and high-tensile steel core.
Bit of a mouthful but that means that it manages a Sold Secure Motorcycle Gold rating and meets the ‘Police Preferred Specification’ of Secured by Design. And if that’s not impressive enough, it also won a Red Dot Design Award 2021 for "perfectly meeting the requirements for a security lock that is simultaneously lightweight while offering the most effective protection possible against theft."
"On-the-go motorcycle security can be cumbersome and usually involves carrying a heavy chain to secure a bike," say LiteLok. "An alarming number of motorcyclists choose not to bother carrying a heavy chain and therefore don’t lock up their bikes when they are out and about on the road."
The unit’s inline locking mechanism is click-to-lock - meaning you only need the key to open it - while the hardened steel lock casings contain a pick-resistant disc detainer-style lock. The rivets are drill-resistant stainless steel and the lock has been tested to -40°C to make sure that it can withstand a freeze-style attack.
The Core Moto weighs just 2.5kg, which LiteLok say is 50% lighter than comparable chains and like their Moto 108 lock, it can be paired with another unit with the same key to extend the length or lock multiple bikes.
Pricing for the Core Moto starts at £149.99 and it’s available in two lengths and three colours.
Been thanked: 7547 times
Re: MCN : LiteLok take lightweight motorbike security to the next level
KungFooBob wrote: Mon Nov 15, 2021 7:25 am
So basically, "a passer by can't walk away with it"
TBF the one you posted does look a bit beefier.
There was a similar article in MCN when they first launched the 'Gold' a year or two back, that's when I found that video and decided it wasn't for me.
Has thanked: 6205 times
Been thanked: 5091 times
weeksy wrote: Mon Nov 15, 2021 7:34 am
LPL uses the floor to help cut the cable. IIRC Zanx used to warn about leaving chains at ground level.
As with the other lock on here recently, it's an 'easy' deterrent (the other was ' to use', this is ' to carry'). A poor lock used is better than a good one not used.
Has thanked: 3267 times
Been thanked: 1738 times
I use a Litelock & alarm disc lock on my Street Triple.
I'm not sure what's a better real world solution for portable motorcycle security?
Has thanked: 9852 times
Been thanked: 10172 times
Bustaspoke wrote: Mon Nov 15, 2021 7:58 am I use a Litelock & alarm disc lock on my Street Triple.
Perhaps riding a shitter for commuting duties is the best deterrent,if no one wants the bike,it won't be stolen. Probably.
Has thanked: 7825 times
Been thanked: 2532 times
Skub wrote: Mon Nov 15, 2021 8:33 am
That
Has thanked: 2556 times
Been thanked: 6263 times
Is it just me, or is the bike in the OP secured to its own plastic plate hanger?
Has thanked: 600 times
Been thanked: 2453 times
Doesn't look like the easiest thing to carry around
I'm more concerned about it getting stolen when I'm out on tour or at a BSB meeting.
I don't ride the bike much for commuting,good fun at 05.30 in May-July but for the rest of the year it's pitch dark in the morning & the same in the evening.I also park the bike right in front of the security hut,so it's always being watched.
We used to have a big problem with bike theft,I work at a big supermarket depot so there's a few bikes there.Ironically the last bike stolen was a little 125 Yamaha,double ironic as the person using it had a BMW S1000 & borrowed his lads 125 as he thought there was less chance of it getting stolen..
Has thanked: 16005 times
Been thanked: 10265 times
MrLongbeard wrote: Mon Nov 15, 2021 9:16 am Doesn't look like the easiest thing to carry around
People wear them as a belt.
The only problem I have with these tests is as Horse says, the chain is on the floor which makes the use of cutting tools much easier. Put a chain that is long enough through the rear wheel and over the seat and the game changes considerably.
Has thanked: 2636 times
Been thanked: 1523 times
Mr. Dazzle wrote: Mon Nov 15, 2021 8:50 am Is it just me, or is the bike in the OP secured to its own plastic plate hanger?
I looked at that and thought "I hope they didn't think that was 'secured'" :)
The Spin Doctor wrote: Mon Nov 15, 2021 9:35 pm
Maybe that's how they carry it. :thumbup:
Skub wrote: Mon Nov 15, 2021 9:37 pm
Horse wrote: Mon Nov 15, 2021 7:47 am LPL uses the floor to help cut the cable. IIRC Zanx used to warn about leaving chains at ground level.
Rather more interesting (IMO) was that he cut the cable in seconds where others appeared to struggle!
It's often difficult NOT to have a chain on the ground - my own isn't long enough to loop over the seat which is what I used to do.
Whysub
Has thanked: 1058 times
Been thanked: 864 times
Post by Whysub »
I was at the MotoGP in Valencia at the weekend. I think this is probably the best way to protect your bike
Asian Boss
Has thanked: 498 times
Been thanked: 650 times
Post by Asian Boss »
Shitter bikes tend to be less safe so one might end up shattering one's pelvis. :(
