LED Headlight Bulbs
Been thanked: 4125 times
LED Headlight Bulbs
I want an LED H4 Headlight bulb for my GSX because it should generate less heartburn the Halogen one - wtf should I buy, the choice is confusing
Has thanked: 839 times
Been thanked: 1242 times
Re: LED Headlight Bulbs
I don't know if it has changed but I think it's still illegal to stick an LED in there as a replacement bulb.
https://www.autobulbsdirect.co.uk/blog/ ... in-the-uk/
Has thanked: 16003 times
Been thanked: 10264 times
I read they are now legal as the new ones generate a proper beam pattern and they will pass the MOT. But I got confused on Amazon and bailed on it!
Interesting, maybe I should just fit a lower wattage halogen bulb, I rarely ride after dark and a 35W would be adequate.
Has thanked: 2948 times
Been thanked: 1884 times
It's a lamp not a bulb, bulbs come up in spring!
Has thanked: 261 times
Been thanked: 1267 times
MingtheMerciless wrote: Sun Nov 14, 2021 3:05 pm It's a lamp not a bulb, bulbs come up in spring!
Sorry, loser.
The English language wrote: Bulb:
the glass housing, in which a partial vacuum has been established, that contains the filament of an incandescent electric lamp
Has thanked: 9849 times
Been thanked: 10171 times
Le_Fromage_Grande wrote: Sun Nov 14, 2021 2:24 pm Interesting, maybe I should just fit a lower wattage halogen bulb, I rarely ride after dark and a 35W would be adequate.
100 watt means 100% chance of being seen.
35 watt? :cry:
JackyJoll wrote: Sun Nov 14, 2021 3:26 pm
Sorry, loser.
Borderline sackable offence to call it a bulb when I was apprenticing.
Skub wrote: Sun Nov 14, 2021 3:27 pm 100 watt means 100% chance of being seen.
That why I use a 200 watt headlight.
200% chance of being seen.
MingtheMerciless wrote: Sun Nov 14, 2021 3:34 pm Borderline sackable offence to call it a bulb when I was apprenticing.
I’ve seen people equally insistent that light bulbs- I mean lamps- must be called globes.
Has thanked: 6205 times
Been thanked: 5091 times
35 watt? :cry:
Balance the risk by wearing a $500 helmet?
Has thanked: 2556 times
Been thanked: 6263 times
Sorry, loser.
See - if you'd asked me to guess, and it would have just been a guess, I'd have said the bulb was the screwy in bit that has filament and the lamp was the complete assembly of bulb, reflector, wires etc.
I'm sure it matters enough to sack someone :thumbup:
I'd call the entire assembly including the reflector the lamp but an LED doesn't have a glass bulb, maybe just call it the diode.
FWIW (not much :) ), on vehicles, a 'lamp' is directional. To be a 'beacon' it must be visible from 360° around the vehicle.
Mussels wrote: Sun Nov 14, 2021 4:19 pm I'd call the entire assembly including the reflector the lamp but an LED doesn't have a glass bulb, maybe just call it the diode.
Or the LED bulb. :lol:
PitaNaanRoti
Has thanked: 25 times
Been thanked: 54 times
Post by PitaNaanRoti »
Best H4 out there is the Osram.
Halfords and Amazon do them.
If you have the trade card then it’s 20% off.
@weeksy I need moderator rights please for misuse of “bulb” 😂.
Has thanked: 5457 times
Been thanked: 13103 times
MingtheMerciless wrote: Sun Nov 14, 2021 5:56 pm @weeksy I need moderator rights please for misuse of “bulb” 😂.
Sure, just paypal £250 for my number plate and you're a mod for a year :)
