Fantasy Garage / Workshop essentials
- Has thanked: 143 times
- Been thanked: 497 times
The build of my garage is well on the way, 3/4 walls are up and the brick pillars will be sorted by the end of the week
Roof joists / boards / epdm roof to follow shortly after
Garage will be used to park cars, storage and as a workshop (as apparently the dining room isn’t for that…), so woodwork, painting, some metal work etc will all be done out there.
Given an unlimited budget and imagination, neither of which I have, what would you include?
My list so far:
PIR controlled lighting
Plumbed airline points connected to compressor
Emergency stop / safe isolation of majority of sockets
Few sockets on permanently to run chargers etc
CCTV camera & Ethernet for wifi (if needed)
My list so far:
- DefTrap
- Has thanked: 2260 times
- Been thanked: 2191 times
- Has thanked: 9828 times
- Been thanked: 10145 times
Re: Fantasy Garage / Workshop essentials
Parker knoll and fridge.
- Has thanked: 599 times
- Been thanked: 2443 times
- Been thanked: 7530 times
- Has thanked: 1264 times
- Been thanked: 1188 times
- Has thanked: 5451 times
- Been thanked: 13087 times
I don't care about car stuff, so mine would just be bikes and bicycles.
So,
3 x Abba Skylift
1 x full sized bike workbench/hydraulic lift.
1 wall allocated to immaculate cupboard space. kitchen style, so lowers, then worktop then upper cabinets too. Plus 2 full height, 1 at each end.
Everything from Park Tools possible.
So,
3 x Abba Skylift
- Has thanked: 257 times
- Been thanked: 332 times
Sadly not possible but a plan is to use lidded boxes / doors & tops for the storage, cars will be parked elsewhere when space is used as a workshop
Currently at 50sqm so difficult unless I steal more of the back garden, there have already been words about me extending the garage this far…
Would love to but the garage roof would need a lift as well
I’ll happily watch you dig / cut through 300mm of reinforced concrete
Good thinking, paint spraying will be restricted to airless system using water based paint but still I’d help
Might transfer a coffee machine out there;)
No space after the cars, two post ramp, Parker knoll, beer fridge, extractor fan, inspection pit
GP bought my abba superbike lift, no two wheeled transport owned or planned at the momentweeksy wrote: ↑Wed Nov 03, 2021 2:35 pm I don't care about car stuff, so mine would just be bikes and bicycles.
So,
3 x Abba Skylift
- Been thanked: 4124 times
Tea room with kettle, fridge and cooker
Toilet
Bathroom
Laundry Area for washing / drying overalls
Proper 4 post car lift
Bike Ramp
Parking for 10 motorcycles
Somewhere to sleep
I think I need an industrial unit
Toilet
Bathroom
Bike Ramp
Somewhere to sleep
No.
You can't take the wheels off using a traditional four post lift, that's why it needs to be a two post.
Depends where the posts are, I can't remember it ever being a problem, but it was over 30 years ago that I used one.KungFooBob wrote: ↑Wed Nov 03, 2021 3:42 pmNo.
There was a bar each side you could lock at different heights, the car rested on these bars when you dropped the ramps away.
Last edited by Le_Fromage_Grande on Wed Nov 03, 2021 4:16 pm, edited 1 time in total.
- Has thanked: 6376 times
- Been thanked: 4753 times
Only really only needs one thing - and the budget is unlimited so:
A full time mechanic.
A four post lift usually just lifts up some ramps that a vehicle has driven on to. You then have a sliding jack in the middle which you can use to jack up the vehicle to get the wheels off.
A two post have fours arms that locate under the jacking points, much better
- Screwdriver
- Has thanked: 256 times
- Been thanked: 740 times
Partitioned off area for dry dusty work. Sawdust, grinding wheels, angle grinder, belt sander etc.
Local extractor (ideally cyclonic separator) in the same space.
Care needed if mixing sawdust and metal grinding. I need to build my own partitioned off area for such purposes. Can't have sawdust all over everything or grinding dust all over the lathe etc.
See my editKungFooBob wrote: ↑Wed Nov 03, 2021 4:15 pm A four post lift usually just lifts up some ramps that a vehicle has driven on to. You then have a sliding jack in the middle which you can use to jack up the vehicle to get the wheels off.
But it's whatever you like, there's benefits to each type, where my Dad used to work they had both and I've used both types, and as it's a fantasy garage you could have one of each.
I've seen too many videos of cars falling off 2 posts lifts, so for a cack handed hobbyist mechanic like myself I'd go for a 4 post jobbie.
Not as much access granted but a hell of a lot less likely to wake up with an upside down car on top of you.
