2010 ZX6R. The wifes trackbike.
- Has thanked: 3804 times
- Been thanked: 2481 times
Re: 2010 ZX6R. The wifes trackbike.
Drain ZX6 and put it in the car. Get 10 litres of Esso super (no ethanol) and jobs a good un. Maybe run it for a few mins to get the non ethanol into the injectors etc. Should be fine in 5 months
Weather forecast doesn't look bad this week, Steve.
If you don't fancy it, I could pop over one afternoon and give it a run up the A34 which would mean it won't get as dirty as running around the lanes.
Kev
Kev
- Has thanked: 5327 times
- Been thanked: 11853 times
Yeah I'm taking the mt07 out for a play tomorrow/Tues. If you fancy an hour I think I'll be out about 1:30 after meetings
Unless I fit the plate hanger, mirrors etc the A34 wouldn't be the best idea
https://revtothelimit.co.uk/app.php/groupsub/subs
https://www.justgiving.com/crowdfunding/steve-weeks-1 - Help support @weeksy08 to go DH Racing.
- Bigyin
- Has thanked: 1377 times
- Been thanked: 2505 times
You know i would take all three prizes on that one ........... i will happily ride it, you can enjoy yourself cleaning it afterwards
This was at the end of a Jan the 1st New Years Day ride out and looking at the front lights you can see where the heat baked the salt on the normal dipped beam light
- Has thanked: 2442 times
- Been thanked: 5535 times
Dragged it out of the garage as it was fairly warm and sunny. Not dry enough on the roads to go out and play but thought i'd at least get the stabiliser through the system fully, so ran it for 10 mins outside... Started first press of the button. First time the key has seen the bike since Pembrey in Aug.
- Has thanked: 8827 times
- Been thanked: 8566 times
Good old Kawasaki.
Just booked it in at MSG racing for a couple of weekend time for full service.
I could arguably do it all myself, but this way I'll get a stamp in the book and make sure an expert has looked it over fully.
Will be curious to see if valve clearances are in or out of spec. May get the steering damper rebuilt too as the adjuster doesn't do much.
- Has thanked: 351 times
- Been thanked: 2140 times
Have we had the steering damper discussion ? None of my zx6 had one or indeed ever felt like they needed one. Is it standard ?
Yup standard. It's more a question of it not working rather than whether it's needed so to speak.
https://www.ebay.co.uk/itm/175052395186 ... SwNnVhkVxp
- Location: For legal reasons everything I post is a joke
- Has thanked: 498 times
- Been thanked: 6572 times
You should treat her to a recent model R1. They seem to be the track bike of choice.
It's what I'd buy, If I did track days and had any money.
Well if you don't need the damper who gives a shit if it works?
Weeksy, that's who.
Weeksy, that's who.
Who says you don't need it? They fitted it to the zx6 for 3 years and the model after has it as an aftermarket performance part option. So clearly Kawasaki thought it may need it.Mr. Dazzle wrote: ↑Mon Jan 10, 2022 9:19 pm Well if you don't need the damper who gives a shit if it works?
Weeksy, that's who.
But it does open a nice debate on track use of one on a 600 for example
The only time I wished I had a damper when I didn't have one was my old R6 on the road.
It had two big hits in the rev range at 10k and 12k, both would make it shake it's head.
Most of the time I classed it as character... except the time I hit 12k at the same time as I hit a level crossing.
I was 100% sure I was dead. Must have gone lock to lock half a dozen times.
Never had anything like that on track.
Well that escalated a little.... coldest morning in the world in the garage... Brrrrrr..
Thought to myself, better drag the bike ready to go tomorrow to MSG Racing...
Then remembered it'll need an MOT in the next few weeks.
Oh bunch of arse, so had to fit the lights, mirrors and number plate etc... Cold still !!!!
Going to get the bolts out for the plate hanger... "oh, bearings.... yeah"... Need to get the rear wheel powder coated and the rear brake line replaced after the non-tightening of the bolt issue. So that's on the list too.
Anyway, it's all good and ready now to take over tomorrow.
- wull
- Has thanked: 792 times
- Been thanked: 1422 times
You don’t need to fit them for the mot, if they’re removed then it will just have an advisory for them. If the lights are fitted and they don’t work then it’s a fail but if they’re removed then it’s ok, same with indicators and mirrors.
- MingtheMerciless
- Has thanked: 2764 times
- Been thanked: 1704 times
I had a first gen R6, it nearly killed me as I came off the A25 onto the A22 towards Caterham, I was accelerating hard leant over when I hit a bump that had never bothered my 7R, it went lock to lock a few times before I knew what had happened and then straightened itself out..........I treated it with a bit more respect after that.KungFooBob wrote: ↑Mon Jan 10, 2022 9:32 pm The only time I wished I had a damper when I didn't have one was my old R6 on the road.
No reason to not fit them, it's 15 minutes work and it needs the plate anyway, which also holds the indicators, so it doesn't add any time really.
