Brexit keys,none of yer foreign metric muck.
Tool purchases
- Has thanked: 9834 times
- Been thanked: 10147 times
Re: Tool purchases
- Has thanked: 5451 times
- Been thanked: 13097 times
- MingtheMerciless
- Has thanked: 2945 times
- Been thanked: 1883 times
Re: Tool purchases
Nice choice Sir (says he who already has the set)
- Has thanked: 2870 times
- Been thanked: 554 times
Re: Tool purchases
Our car is due its 80k miles service soon which includes a Haldex service so I need a Haldex oil filter wrench. £12 from eBay.
Also bought some Facom ratchet spanners, well one spanner with interchangeable bits. I've already got ratchet spanners but the Facom are six point as opposed to twelve so that was my excuse for buying.
- Has thanked: 144 times
- Been thanked: 497 times
Re: Tool purchases
I hope you are going to ask an appropriate adult to use them for you…Beancounter wrote: ↑Fri Oct 29, 2021 5:57 pm Our car is due its 80k miles service soon which includes a Haldex service so I need a Haldex oil filter wrench. £12 from eBay.
I do like the ratchet spanner set though!
- Has thanked: 10269 times
- Been thanked: 6887 times
Re: Tool purchases
I bought a set of ratchet spanners about 5 years. Looked great.
Only ever used them once
- Has thanked: 1347 times
- Been thanked: 1722 times
Re: Tool purchases
Taipan wrote: ↑Wed Oct 27, 2021 1:47 pmJust took a punt on three of these (untested) for £12.50!demographic wrote: ↑Mon Oct 25, 2021 7:01 pm Got this a while ago, think it was about fifteen quid secondhand.
Torque screwdriver.
1 x Red Torquemaster Standard: (8 ozf in - 36 lbf-in) (600 gmf cm - 40 kgf cm) (6 - 406 c N m).
1 x Red Torquemaster Standard: 8 oz-in to 36 lb-in. Left & Right Hand
1 x Green Torquemaster Minor: 3 oz-in to 12 lb-in.
I like the way they have a 1/4" square drive socket in the handle as well.
Think you likely got a great deal there.
Not for everyday use but some pushbikes have some pretty small bolts into aluminium and the usual technique of turn it til the thread strips then back off a quarter turn isn't the best idea.
- DefTrap
- Has thanked: 2265 times
- Been thanked: 2193 times
- Been thanked: 2618 times
Re: Tool purchases
Why the 90 degree bend in the wrench?
And what keeps the inserts in the spanner when in use?
- DefTrap
Re: Tool purchases
It's almost impossible to reach the haldex filter with a normal wrench, it's tucked behind various other chassis parts
Re: Tool purchases
Where’s the fun in that?
Once every 40k miles so I can’t imagine I’ll use it more than once. Saying that it’s debatable I’ll even use the once.
Think it’s because access to the filter is restricted.
Kind of resistance fit.cheb wrote: And what keeps the inserts in the spanner when in use?
- DefTrap
Re: Tool purchases
You can wiggle it in with fingers but no way are you tightening it wo a spanner
- Has thanked: 6381 times
- Been thanked: 4761 times
Re: Tool purchases
May be of interest. Just been to Screwfix and they have an offer on Makita impact driver + drill + 2 × 18v Li-ion batteries for £180 (£40 off).
Almost worth me getting it just for the 2 batts and driver. But I resisted.
- Has thanked: 599 times
- Been thanked: 2445 times
- the_priest
- Has thanked: 1874 times
- Been thanked: 2170 times
Re: Tool purchases
46mm combination spanner for the Speed Triple's rear wheel nut. Might be able to get it off now.
- Cousin Jack
- Has thanked: 2553 times
- Been thanked: 2287 times
Re: Tool purchases
Should have bought a 46mm socket.the_priest wrote: ↑Tue Nov 30, 2021 9:23 am 46mm combination spanner for the Speed Triple's rear wheel nut. Might be able to get it off now.
And a BIG breaker bar!
- the_priest
Re: Tool purchases
The spanner is 50cm long and I have rather strong hands according to my physio, I did not break the strength gauge, but I did put the numbers higher than she has ever seen them go....Cousin Jack wrote: ↑Tue Nov 30, 2021 9:52 amShould have bought a 46mm socket.the_priest wrote: ↑Tue Nov 30, 2021 9:23 am 46mm combination spanner for the Speed Triple's rear wheel nut. Might be able to get it off now.
I will probably get a socket too, but the spanner was £8 delivered off Ebay.
