A right now thread
Has thanked: 20836 times
Been thanked: 13634 times
Re: A right now thread
Waiting for breakdown recovery! Rode the Tmax about 15 miles from London to Romford to turn step mothers heating on snd came out 5 minutes later to a flat battery!! 🙄 Been online snd bought a second hand regulatir just in case! 👍
Has thanked: 3633 times
Been thanked: 2497 times
Just finished fish n chips, drinking cider and don't have to get up for work tomorrow as I'm on a late turn.
Has thanked: 6120 times
Been thanked: 15472 times
Taipan wrote: Wed Sep 29, 2021 6:35 pm Waiting for breakdown recovery! Rode the Tmax about 15 miles from London to Romford to turn step mothers heating on snd came out 5 minutes later to a flat battery!! 🙄 Been online snd bought a second hand regulatir just in case! 👍
And a new battery?
Has thanked: 778 times
Been thanked: 3212 times
Just knocked out 3.5 k on the rower and washed the pots
weeksy wrote: Wed Sep 29, 2021 7:08 pm
And a new battery?
It doesn't smell cooked, so if it is the regulator, it's been undercharging? The battery is taking a charge with no hiccups?
Taipan wrote: Wed Sep 29, 2021 8:03 pm
And a new battery?
What makes you say the battery is taking the charge? I'm not arguing it, but you've not shown us why that's the case?
weeksy wrote: Wed Sep 29, 2021 9:38 pm
And a new battery?
Its on an optimate iv which checks it before charging, but it just took a charge straight away. Faulty regulators either under or overcharge. When they overcharge they boil the battery and you'll certainly smell it and the battery is hot to touch. I have none of that, so I expect the regulator is undercharging? Don't get me wrong, if it needs a battery, it can certainly have one, it just doesn't appear to need one.
I've never really trusted the optimate in terms of that
I've seen loads laid up and optimate says "good to go" then nada.
People swear "it says it's fine"
They put on a new battery and it starts first press.
I'd be going multimeter to confirm rather than the optimate
Has thanked: 712 times
Been thanked: 2028 times
weeksy wrote: Wed Sep 29, 2021 10:06 pm I've never really trusted the optimate in terms of that
All of that ^^ I dont even trust trickle charge over the winter months. I rather take battery out and keep it worm in the house and if needed charge come when needed again.
A multimeter won't test it, it'll just read the battery's voltage? The only real way to test a battery is a load tester, but I don't have one of those obvs. Regardless, I have to charge it to start it and check what the voltage across the terminals is. Then I'll know if it's the regulator, I just hope it isn't the alternator/stator. Not saying it isn't the battery of course, but it's very unusual to have run a bike for 45 minutes over 10 miles and it not start 5 minutes later?
The battery charged okay according to the optimate. Put it on and with the leads connected it was 12.8v. Ran the bike and the reading stayed the same. It isn't charging.
DMM will tell you the battery voltage, so charge the battery and if a cell has failed you’ll see a lower voltage than normal. Eg 9V rather than 13V on it once it comes off the charger.
But if it’s just beginning to fail, to properly test it you need a Hioki or Yuasa battery tester that measure the battery’s internal resistance ( but they are rather expensive - about 1K)
MingtheMerciless wrote: Thu Sep 30, 2021 8:49 am DMM will tell you the battery voltage, so charge the battery and if a cell has failed you’ll see a lower voltage than normal. Eg 9V rather than 13V on it once it comes off the charger.
I grew up using the below! :D Whatever the battery state, it won't change the charge output rate at the terminals, or at least that's always been the defining diagnostic for me. Plus, these bikes are pretty notorious for reg faults. They get too hot behind the panels where the engine heat pretty much gets directed.
DefTrap
Has thanked: 1838 times
Been thanked: 1468 times
Post by DefTrap »
Yeah ive had limited success ressurrecting batteries once they go off. It's only a matter of time before it'll strand you.
I congratulated myself pulling a bike battery back from the dead, rode into town, it cut out. No amount of bumping or jumping would restart it, it was a long push home again.
Has thanked: 8022 times
Been thanked: 5677 times
What you need TP, is a scoot with a bigger battery.
8-)
Has thanked: 12578 times
Been thanked: 8531 times
Potter wrote: Thu Sep 30, 2021 10:20 am
DefTrap wrote: Thu Sep 30, 2021 8:58 am Yeah ive had limited success ressurrecting batteries once they go off. It's only a matter of time before it'll strand you.
I'm a sucker for this, I hate throwing things away, so even though I know a battery is knackered I'll still try voodoo to make it last a bit longer. On a two stroke with kickstart I can get away with it indefinitely, but it's caught me out on other stuff, you can't bump start a boat.
Not even on a hill?
I've had quite a bit of success reviving deeply discharged batteries, i.e. completely flat with zero voltage showing on a meter, but if a cells gone, it's over!
Has thanked: 1080 times
Been thanked: 1010 times
Post by slowsider »
Count Steer wrote: Thu Sep 30, 2021 10:02 am What you need TP, is a scoot with a bigger battery.
8-)
He's part way to this
https://gaadiwaadi.com/yamaha-unveils-e ... ping-tech/
Taipan wrote: Thu Sep 30, 2021 8:44 am The battery charged okay according to the optimate. Put it on and with the leads connected it was 12.8v. Ran the bike and the reading stayed the same. It isn't charging.
Started a thread about this in the mechanics forum if anyone wants to help?
viewtopic.php?f=12&t=3857&p=108508#p108508
Taipan wrote: Fri Oct 01, 2021 3:37 pm
Leccy is voodoo to me :(
