A right now thread
- Has thanked: 20836 times
- Been thanked: 13634 times
Re: A right now thread
Waiting for breakdown recovery! Rode the Tmax about 15 miles from London to Romford to turn step mothers heating on snd came out 5 minutes later to a flat battery!!
Been online snd bought a second hand regulatir just in case!
- MingtheMerciless
- Has thanked: 3633 times
- Been thanked: 2497 times
Just finished fish n chips, drinking cider and don't have to get up for work tomorrow as I'm on a late turn.
- Has thanked: 6120 times
- Been thanked: 15472 times
And a new battery?Taipan wrote: Wed Sep 29, 2021 6:35 pm Waiting for breakdown recovery! Rode the Tmax about 15 miles from London to Romford to turn step mothers heating on snd came out 5 minutes later to a flat battery!!Been online snd bought a second hand regulatir just in case!
- Has thanked: 778 times
- Been thanked: 3212 times
It doesn't smell cooked, so if it is the regulator, it's been undercharging? The battery is taking a charge with no hiccups?weeksy wrote: Wed Sep 29, 2021 7:08 pmAnd a new battery?Taipan wrote: Wed Sep 29, 2021 6:35 pm Waiting for breakdown recovery! Rode the Tmax about 15 miles from London to Romford to turn step mothers heating on snd came out 5 minutes later to a flat battery!!Been online snd bought a second hand regulatir just in case!
What makes you say the battery is taking the charge? I'm not arguing it, but you've not shown us why that's the case?Taipan wrote: Wed Sep 29, 2021 8:03 pmIt doesn't smell cooked, so if it is the regulator, it's been undercharging? The battery is taking a charge with no hiccups?weeksy wrote: Wed Sep 29, 2021 7:08 pmAnd a new battery?Taipan wrote: Wed Sep 29, 2021 6:35 pm Waiting for breakdown recovery! Rode the Tmax about 15 miles from London to Romford to turn step mothers heating on snd came out 5 minutes later to a flat battery!!Been online snd bought a second hand regulatir just in case!
Its on an optimate iv which checks it before charging, but it just took a charge straight away. Faulty regulators either under or overcharge. When they overcharge they boil the battery and you'll certainly smell it and the battery is hot to touch. I have none of that, so I expect the regulator is undercharging? Don't get me wrong, if it needs a battery, it can certainly have one, it just doesn't appear to need one.weeksy wrote: Wed Sep 29, 2021 9:38 pmWhat makes you say the battery is taking the charge? I'm not arguing it, but you've not shown us why that's the case?
I've never really trusted the optimate in terms of that
I've seen loads laid up and optimate says "good to go" then nada.
People swear "it says it's fine"
They put on a new battery and it starts first press.
I'd be going multimeter to confirm rather than the optimate
- Felix
- Has thanked: 712 times
- Been thanked: 2028 times
All of that ^^ I dont even trust trickle charge over the winter months. I rather take battery out and keep it worm in the house and if needed charge come when needed again.weeksy wrote: Wed Sep 29, 2021 10:06 pm I've never really trusted the optimate in terms of that
A multimeter won't test it, it'll just read the battery's voltage? The only real way to test a battery is a load tester, but I don't have one of those obvs. Regardless, I have to charge it to start it and check what the voltage across the terminals is. Then I'll know if it's the regulator, I just hope it isn't the alternator/stator. Not saying it isn't the battery of course, but it's very unusual to have run a bike for 45 minutes over 10 miles and it not start 5 minutes later?weeksy wrote: Wed Sep 29, 2021 10:06 pm I've never really trusted the optimate in terms of that
The battery charged okay according to the optimate. Put it on and with the leads connected it was 12.8v. Ran the bike and the reading stayed the same. It isn't charging.
- MingtheMerciless
DMM will tell you the battery voltage, so charge the battery and if a cell has failed you’ll see a lower voltage than normal. Eg 9V rather than 13V on it once it comes off the charger.
But if it’s just beginning to fail, to properly test it you need a Hioki or Yuasa battery tester that measure the battery’s internal resistance ( but they are rather expensive - about 1K)
I grew up using the below!MingtheMerciless wrote: Thu Sep 30, 2021 8:49 am DMM will tell you the battery voltage, so charge the battery and if a cell has failed you’ll see a lower voltage than normal. Eg 9V rather than 13V on it once it comes off the charger.
- DefTrap
- Has thanked: 1838 times
- Been thanked: 1468 times
Yeah ive had limited success ressurrecting batteries once they go off. It's only a matter of time before it'll strand you.
I congratulated myself pulling a bike battery back from the dead, rode into town, it cut out. No amount of bumping or jumping would restart it, it was a long push home again.
- Has thanked: 8022 times
- Been thanked: 5677 times
What you need TP, is a scoot with a bigger battery.
- Has thanked: 12578 times
- Been thanked: 8531 times
Not even on a hill?Potter wrote: Thu Sep 30, 2021 10:20 amI'm a sucker for this, I hate throwing things away, so even though I know a battery is knackered I'll still try voodoo to make it last a bit longer. On a two stroke with kickstart I can get away with it indefinitely, but it's caught me out on other stuff, you can't bump start a boat.DefTrap wrote: Thu Sep 30, 2021 8:58 am Yeah ive had limited success ressurrecting batteries once they go off. It's only a matter of time before it'll strand you.
I've had quite a bit of success reviving deeply discharged batteries, i.e. completely flat with zero voltage showing on a meter, but if a cells gone, it's over!DefTrap wrote: Thu Sep 30, 2021 8:58 am Yeah ive had limited success ressurrecting batteries once they go off. It's only a matter of time before it'll strand you.
- Has thanked: 1080 times
- Been thanked: 1010 times
Started a thread about this in the mechanics forum if anyone wants to help?Taipan wrote: Thu Sep 30, 2021 8:44 am The battery charged okay according to the optimate. Put it on and with the leads connected it was 12.8v. Ran the bike and the reading stayed the same. It isn't charging.
viewtopic.php?f=12&t=3857&p=108508#p108508
Leccy is voodoo to meTaipan wrote: Fri Oct 01, 2021 3:37 pmStarted a thread about this in the mechanics forum if anyone wants to help?Taipan wrote: Thu Sep 30, 2021 8:44 am The battery charged okay according to the optimate. Put it on and with the leads connected it was 12.8v. Ran the bike and the reading stayed the same. It isn't charging.
