E10 in an old bike
- Has thanked: 498 times
- Been thanked: 650 times
E10 in an old bike
I panic-filled the XL with E10 a few days back.
It's a 1984 bike so not compatible. Any idea how quickly I need to get it out before it banjaxes something?
I've been using it to try and run the level down but it uses so little it's never going to work.
- Been thanked: 7545 times
Re: E10 in an old bike
It's going to be utterly fucked by now.
I'll give £250 for it, but I'm cutting my own throat.
Or you could put some of this (or similar) in it.
https://www.toolstation.com/b3c-ethanol ... lsrc=aw.ds
- Has thanked: 9848 times
- Been thanked: 10163 times
Never mind that E10 bollox,just gan it up on t' back wheel.
- Bigyin
- Has thanked: 1413 times
- Been thanked: 2680 times
As i understand it the problem is either continued use of E10 or leaving it to stand with E10 in it which will have an effect on a plastic tank or carb rubbers.
I doubt a single tank will fuck it but 50 quid and i'll take it off your hands to remove the stress and worry for you
- Screwdriver
- Has thanked: 256 times
- Been thanked: 740 times
I rather suspect the bigger problem will be chainsaws, strimmers and other petrol driven garden paraphernalia. All plastic tanks, none of the buggers ever want to start anyway after six months tucked away in the shed.
It's a deliberate act of sabotage! </tinfoilhat>
- DefTrap
- Has thanked: 2269 times
- Been thanked: 2194 times
My chainsaw has had e10 in it for ages. Bikes too.
I tend to think there's a lot of people with shit machinery and terrible maintenance schedules just looking for excuses.
- Been thanked: 2623 times
And for all the amount domestic garden machinery uses it's no great expense to use Aspen petrol or petroil.
Thanks chaps. Maybe I shouldn't papper mesen.
It really uses so little, the level's still up in the filler neck.
I think using E5 super unleaded could also be an answer (to a problem which may not exist...!).
- Screwdriver
- Has thanked: 600 times
- Been thanked: 2453 times
You mean chucking it in the back of the shed until next year isn't a good thing?
Ah well, it's worked so far for the Hayter so I'll keep the schedule going
- wull
- Has thanked: 881 times
- Been thanked: 1553 times
Going by the fuel Shenanigans at the moment the £10 fuel is worth around £367 so ignore the offers and double the price
- Been thanked: 4125 times
Fuel separation and the following water absorption causes the green slime, the bigger problem is the ethanol damaging rubber parts, some it shrinks, some it grows, some harden, some dissolve, but if you use it regularly so the fuel doesn't sit, it seems to be less of a problem.
My 31 year old FZ750 gets used regularly and doesn't seem to have any problems, my Kawasaki I rarely use and I have loads of carb problems.
- Has thanked: 2556 times
- Been thanked: 6263 times
You wouldn't believe how many tedious arguments (or maybe you would) there are in OEMs and the like about tiny little details like that. It's the difference between a proper OEM product and something made in your shed.
As for ethanol - the auld Triumph has been upgraded with ethanol resistant seals and floats throughout. We shall see if they actually work! I think it might be a moot point anyway, 'cause the fancy high octane fuel she needs on account of her high compression pistons doens't actually have ethanol in AFAIK.
There was a big post on FB from a chemical engineer about E10. Short version, just use it as normal. Fuel injected bikes can use it OK but older ones with carbs might find it rotting seals if used over a long period. Just burn it as normal and revert to E5 (which ain't great but it's better). Fuel stabiliser does nothing as the ethanol is still present and will absorb water if kept in the bike for long periods. For storage drain it down and put a few litres of alkylene fuel (such as Aspen) in it.
