- Has thanked: 833 times
- Been thanked: 1237 times
It might work if the battery is big enough and you can tell it when to run the engine, i.e. you can make sure you have a full battery when you are about to start the climb.
That still won't help if the brakes are inadequate on the way down, maybe they should mount a huge resistor on the roof to burn off extra energy.
- Has thanked: 2548 times
- Been thanked: 6230 times
You've been reading my e-mails haven't you?
- Been thanked: 2610 times
They need to build risk assessment into satnavs taking expected speeds, loads and gradients into account.
Big descent after 50 miles but the battery will not exceed 90% by the time you get to the bottom as long as you don't recharge at any of the 3 previous charging stations. This is followed by a long climb and to make the summit the battery must be topped off to a minimum of 80% between these two points.
They've already started doing stuff like that. SatNav informed vehicle settings have been around for a while - top spec Mercs and Beemers will pre-emptively change down when approaching hills and bends for example so it's less obvious to the passengers.
I'd be very very surprised if EVs are not already well along the road towards changing the way they operate based on what's coming up on the route.
Better than having the batteries sink your boat.Potter wrote: ↑Mon Sep 13, 2021 12:38 pm The biggest issue I have with ICE at the moment is the complexity and the maintenance, I'm tired of rebuilding them, my boat engine seems to break for fun, I look forward to have an electric motor where you just send it away and put another one in if it breaks.
Modern electric motors are obviously fantastically complicated. But crucially the vast majority of the complexity is in stuff which doesn't move. And well all know how much the home mechanic loves dealing with electrical and software issues!Potter wrote: ↑Mon Sep 13, 2021 12:38 pm The biggest issue I have with ICE at the moment is the complexity and the maintenance, I'm tired of rebuilding them, my boat engine seems to break for fun, I look forward to have an electric motor where you just send it away and put another one in if it breaks.
Yeah agreed.
Trouble is, most EVs don't have motors alone, they have so called "Electric Drive Units" which also contain all the gears and bearings etc. Theyre only ever gonna get more and more integrated.
So you won't be able to take the motor out....you'll be taking the whole back axle out. I imagine in a few years times there will be independent garages offering rebuild/refurb services.
It means you don't need two casings, two sets of bearings and so on. Everything's lighter, smaller and cheaper.
Bear in mind that we get pushed to shave 2mm off of the outer casing size....
- Has thanked: 218 times
- Been thanked: 689 times
Have a look at Rich Rebuilds on youtube...he does a lot with Tesla stuff.
- Has thanked: 325 times
- Been thanked: 2173 times
Our Merc in electric mode reads the road, as I let off the accelerator approaching a corner or roundabout the amount of regen increases as you get closer, takes some getting used too and manually adjusting regen as you drive with the paddles means you rarely need to use the actual brakes. The harder you come off the accelerator too the harder the car stops on regen alone. Can get another 10-15% range doing it properlyMr. Dazzle wrote: ↑Mon Sep 13, 2021 12:06 pm They've already started doing stuff like that. SatNav informed vehicle settings have been around for a while - top spec Mercs and Beemers will pre-emptively change down when approaching hills and bends for example so it's less obvious to the passengers.
Aye....the old "one pedal" driving
The few times I've driven an EV around MK I've found "super eco mode" the best for getting around quickly. Maximum regen on the pedal.
- Has thanked: 1342 times
- Been thanked: 1719 times
Pretty sure I've seen stuff on the fully charged show about them using electric motors on boats round Amsterdam and also on a ferry near Stockholm.
The ferry was just for something like a 20 minute journey and had some massive cables to charge it up but hell, it was a ferry so pretty massive its self.
Neither of them had solar panels admittedly but the launch round Amsterdam was just nice and quiet.
- Has thanked: 1264 times
- Been thanked: 1188 times
nice little diesel engine should do it...
Oh...
- Has thanked: 6176 times
- Been thanked: 5079 times
Pedalo conversion?
But a man of Potter's means can afford to buy a paddle. Or take along a pair of whores to do the rowing.
That might wear out his rowlocks.
demographic wrote: ↑Mon Sep 13, 2021 5:51 pm Pretty sure I've seen stuff on the fully charged show about them using electric motors on boats round Amsterdam and also on a ferry near Stockholm.
Electric launches are quite common around Holland in general.
Appropo of being a dinosaur.....I was in the small lock at Zandaam a while back ( must have been about 4 years ago now!) in Mascotte, which has a 475 Daf....we were in with a few other boats some quite small day launches. The keeper calked me out first, so i opened the throttle to get her moving (27 tons....) and looked starboard to see the lady in the launch along side get a face full of diesel. ...these old dafs choke up a bit on idle.....
- Has thanked: 664 times
- Been thanked: 1153 times
Loads of gadgets and car sim etc. So far so good.
- 7C4308B7-6383-43C4-A3AF-6B7052CB8843.jpeg (1.85 MiB) Viewed 141 times
Is that green plate tag a regulatory thing? Saw lots when I was last over
