Spacers/ M10 bolts with large heads
Deadpool2
Has thanked: 294 times
Been thanked: 68 times
Post by Deadpool2 »
On my bike project thread I (well Steve fitted a centre stand). Unfortunately turns out the stand bolts are about 2mm too high causing the stand to hit the exhaust.
What I need to find is either a M10 bolt which has a 2mm bigger head or some spacers - about 2-3mm wide which I can use to move the stand down a bit.
Any idea of where I can try and get this from. An online search did not reveal anything.
thanks
Re: Spacers/ M10 bolts with large heads
M10 washers used as spacers?
Deadpool2
Post by Deadpool2 »
good point cheers - I will have to nip to the tool shop
Has thanked: 1829 times
Been thanked: 1469 times
I bought some M6 and M8 spacers from eBay recently for mounting a screen on the Diavel ... but they were 3mm, 7.5 and 10 mm. 3 mm is 3 washers, right?
Deadpool2
Post by Deadpool2 »
Yes, I guess I was just hoping for something more substantial and I will have to cut the new bolt slightly.
Hairybiker84
Has thanked: 70 times
Been thanked: 108 times
Post by Hairybiker84 »
Do you just need a 2mm thicker head to the bolt? Socket head bolts usually have a thicker head than hex head. You can find standard drawings of bolt dimensions online.
Deadpool2
Post by Deadpool2 »
Yes thanks, but it currently a socket head
Has thanked: 2551 times
Been thanked: 6245 times
I gotta ask, cause I just can't picture it...how does having a different sized bolt head help here?
I'm sure there's a reason, but like I said I can't picture it. I'm curious more than anything.
Been thanked: 7530 times
I reckon it's all Weeksy's fault.
Has thanked: 5451 times
Been thanked: 13087 times
Mr. Dazzle wrote: Thu Aug 26, 2021 9:57 pm I gotta ask, cause I just can't picture it...how does having a different sized bolt head help here?
I agree. The space is defined by the sidestand, which is a set width by design, the dimensions are, well, what they are. You can't make it wider, unless you cut it
The only thing I could see work is spacers on one side, but offset by a smaller bracket of the opposite side, which would move it by that distance either side.
Even having fitted it, I'm struggling to see how it can be changed
Tricky
Has thanked: 2565 times
Been thanked: 2680 times
Post by Tricky »
Me too- @Deadpool2 - pics are required! (or a nice little hand-drawn diagram would also probably suffice ) :thumbup:
Has thanked: 6191 times
Been thanked: 5087 times
Deadpool2 wrote: Thu Aug 26, 2021 10:02 am causing the stand to hit the exhaust.
Could it be that the stand will swing up until it meets 'something', so what you actually need to add is a 'stop' of some type, such as a rubber block* on the frame.
* Otherwise, if the stand moves at all over bumps, you'll get a free gong if it's metal to metal
Unless there is a positive stop or limit on movement built into the stand, then just offsetting it might not help.
Deadpool2
Post by Deadpool2 »
Sorry been busy at work. Here is the issue, I think the stand has multiple applications and it's apparently a known fault, sigh., one I didn't know about obviously.
Here is the picture
Deadpool2
Post by Deadpool2 »
This is how it should fit, but then runs the exhaust. On the plus side there is no way an aftermarket exhaust will work so that's saves a fortune lol
And a bug thanks to Steve for just figuring out how it fits
