Twenty two hours in the garage
- Been thanked: 4124 times
Re: Twenty two hours in the garage
I prefer the smell of burning Castrol A545 in the morning.
- Has thanked: 6382 times
- Been thanked: 4763 times
What does it remind you of?Le_Fromage_Grande wrote: ↑Tue Aug 24, 2021 9:42 am I prefer the smell of burning Castrol A545 in the morning.
FreedomCount Steer wrote: ↑Tue Aug 24, 2021 9:45 amWhat does it remind you of?Le_Fromage_Grande wrote: ↑Tue Aug 24, 2021 9:42 am I prefer the smell of burning Castrol A545 in the morning.
- Has thanked: 7821 times
- Been thanked: 2531 times
Just like a WW1 pilot then, they used to get coated with it.Potter wrote: ↑Tue Aug 24, 2021 10:17 amI tried, they don't work.Count Steer wrote: ↑Tue Aug 24, 2021 8:08 am You can buy 'Castrol R' candles. Just the thing for that romantic ambience in the garage.
I even got an oil lamp and put R in it and then burned that, but again it's not the same.
The only time I've been fed up with it was following another bloke on his Rudge that was burning serious amounts of oil, after an hour or so behind him it was a bit too sickly
- Been thanked: 2618 times
Is there any truth to the rumour that WW1 pilots always had the shits due to the amount of castor oil ingested?
I believe that it's documented (sort of), so yes. (but I'm not sure they talked about it that much in those days)
- Has thanked: 16232 times
- Been thanked: 3931 times
I've had a not great few days and watching and listening to that has made me smile heaps!! I think I'll keep it saved so I can have a cheer up when I need it!! LOL
Bloody LOVE that smell. Was the second best bit about the Manx GP - standing trackside and as the bikes come into earshot, stick fingers in ears and breathe out hard ready to have a really good lungful of the smell as they went past!!!!
I think anyone would be having the shits doing what they did regardless of what they ingested.
- Been thanked: 7539 times
Shame you can't just drill out the holes to 3/8"
- Has thanked: 2552 times
- Been thanked: 6260 times
Love the fact an Amal concentric is considered an upgrade here. I've seen them described elsewhere as a barely controlled fuel leak
Would seem to be the massively easier option, it's only 1/16" bigger.
Can't tell from the pic but there should be 1/32"+ clearance of that 'O' ring.Le_Fromage_Grande wrote: ↑Wed Aug 25, 2021 8:48 amWould seem to be the massively easier option, it's only 1/16" bigger.
It looks like it would be possible to widen the holes with a file rather than drilling to ensure you don't compromise that distance between the o-ring slot and the mounting hole.Count Steer wrote: ↑Wed Aug 25, 2021 8:53 amCan't tell from the pic but there should be 1/32"+ clearance of that 'O' ring.Le_Fromage_Grande wrote: ↑Wed Aug 25, 2021 8:48 amWould seem to be the massively easier option, it's only 1/16" bigger.
Wouldn't take that long, but annoyingly manual.
Bit of a bodge though. The hole looks to have a slight chamfer on so there's probably more meat to play with than might appear at first glance at the pic.Rockburner wrote: ↑Wed Aug 25, 2021 8:59 amIt looks like it would be possible to widen the holes with a file rather than drilling to ensure you don't compromise that distance between the o-ring slot and the mounting hole.Count Steer wrote: ↑Wed Aug 25, 2021 8:53 amCan't tell from the pic but there should be 1/32"+ clearance of that 'O' ring.Le_Fromage_Grande wrote: ↑Wed Aug 25, 2021 8:48 am
I'm sure there'll be a pillar drill in the tool kit. Just needs a good clamping arrangement.
But as you have a lathe why not cut the correct cycle 26tpi thread on that rather than using metric which some future owner will curse you for* (not to mention having to carry a special spanner just for them). Anyway a 5/16 cycle thread die is oinly a few quid from Tracy tools and you'll find lots more use for it.
With regard to the concentric, they're not that bad but I would use a monobloc as fitted to my ES2.
Also, your shop down the road must be better than the ones by me if they have Whitworth bolts in stock!
*I speak as someone who restored an Ariel Arrow a few years ago that a previous owner had seen fit to assemble with metric gutter bolts and square nuts.
Yeah what kind of silly cnt would (fail to) ride a classic with hot cams, upgraded internals and racey fuelling?
You'd never find a Triumph owner being that daft, that's for sure.Mr. Dazzle wrote: ↑Wed Aug 25, 2021 9:03 pmYeah what kind of silly cnt would (fail to) ride a classic with hot cams, upgraded internals and racey fuelling?
- Has thanked: 2249 times
- Been thanked: 1243 times
Great thread....
My old dad had a Rudge 500 back in the day, have a picture of him on it as a youth somewhere - have to dig it out.
