Could be,hard to see.Mr. Dazzle wrote: ↑Mon Aug 23, 2021 2:01 pmYeah thats what the pic shows? Unless my eyes is playin' tricks?
Fitting new brake master cylinder / reservoir
- Has thanked: 9841 times
- Been thanked: 10155 times
Re: Fitting new brake master cylinder / reservoir
- Has thanked: 2552 times
- Been thanked: 6262 times
Dowty seals...
IME it'd be highly unusual to see anything other than these on hydraulic banjo connections on most industrial kit. Theyre also fitted to plenty of car and aircraft connections IME, including suspension and gearbox stuff.
I've heard people say that brake fluid attacks them, but I'd be surprised if that's the case. As above, they're pretty much the default on most hydraulic connections and what's brake fluid if not hydraulic fluid?
That said, chemistry is a funny old mistress. But if the brake supplier sent 'em....
- Has thanked: 146 times
- Been thanked: 498 times
And even if you replace all of the washers with brand new ones, it isn’t beyond the realms of possibility that one will get pinched and have you scratching your head…Druid wrote: ↑Sat Aug 21, 2021 9:42 am My easy bleeding tip:
Take the caliper off and pump the pistons almost all the way out. Bolt your new braided hose to the new m/c, undo the hose from the caliper and bolt the new hose to it. Fit the new m/c to the bars and push the pistons all the way in to the caliper. This will force the brake fluid into the new brake line and up into the m/c reservoir. Refit the caliper and bleed with new fluid.
Oh yes, new copper washers on both banjos
…thankfully a brew gave sufficient peace of mind to strip it out and check each washer in turn.
