Sticking Ignition.
- Has thanked: 12556 times
- Been thanked: 8517 times
Sticking Ignition.
The key is sticking on the GSXR and sometimes a bit hard to turn or pull out.
Tried WD40 but no change. Is it safe to drip some oil into the lock?
Any advice?
Any advice?
- Been thanked: 9454 times
Re: Sticking Ignition.
The proper stuff for the job is graphite powder/spray.
It's non-sticky so the lock won't gum up with dust and dirt sticking to the oil.
porter_jamie
- Has thanked: 253 times
- Been thanked: 140 times
yeah i got some graphite powder for the front door lock as the lock was really expensive, and said specifically in the packaging never use wd40
There is a trick you can do with a pencil to coat the key in graphite, but I've never been convinced.
- ChrisW
- Has thanked: 3714 times
- Been thanked: 3027 times
- ChrisW
I've ground a pencil lead into locks before & it's worked. Works on zips too.KungFooBob wrote: Thu Mar 16, 2023 4:56 pm There is a trick you can do with a pencil to coat the key in graphite, but I've never been convinced.
- Has thanked: 8007 times
- Been thanked: 5665 times
Chances are you have proper graphite pencil leads. Not all pencils are equal.ChrisW wrote: Thu Mar 16, 2023 4:57 pmI've ground a pencil lead into locks before & it's worked. Works on zips too.KungFooBob wrote: Thu Mar 16, 2023 4:56 pm There is a trick you can do with a pencil to coat the key in graphite, but I've never been convinced.
- ChrisW
Fair point!Count Steer wrote: Thu Mar 16, 2023 5:00 pmChances are you have proper graphite pencil leads. Not all pencils are equal.ChrisW wrote: Thu Mar 16, 2023 4:57 pmI've ground a pencil lead into locks before & it's worked. Works on zips too.KungFooBob wrote: Thu Mar 16, 2023 4:56 pm There is a trick you can do with a pencil to coat the key in graphite, but I've never been convinced.![]()
Works on Guitar nuts too,but messy as fook.ChrisW wrote: Thu Mar 16, 2023 4:57 pmI've ground a pencil lead into locks before & it's worked. Works on zips too.KungFooBob wrote: Thu Mar 16, 2023 4:56 pm There is a trick you can do with a pencil to coat the key in graphite, but I've never been convinced.
I'm a Tombow fanboi.ChrisW wrote: Thu Mar 16, 2023 5:18 pmFair point!Count Steer wrote: Thu Mar 16, 2023 5:00 pmChances are you have proper graphite pencil leads. Not all pencils are equal.ChrisW wrote: Thu Mar 16, 2023 4:57 pm
I've ground a pencil lead into locks before & it's worked. Works on zips too.![]()
- ChrisW
I used to get Blackwings but haven't had any for ages.Count Steer wrote: Thu Mar 16, 2023 5:42 pmI'm a Tombow fanboi.ChrisW wrote: Thu Mar 16, 2023 5:18 pmFair point!Count Steer wrote: Thu Mar 16, 2023 5:00 pm
Chances are you have proper graphite pencil leads. Not all pencils are equal.![]()
Just been looking at Tombow, I assume they're good so I've ordered one of their mechanical pencils for my youngest daughter (she prefers mechanical)
Tombow areChrisW wrote: Thu Mar 16, 2023 5:47 pmI used to get Blackwings but haven't had any for ages.
- ChrisW
Cheers but also darn it - they have them cheaper than the place I ordered from. Also just bought some Blackwings for meCount Steer wrote: Thu Mar 16, 2023 6:00 pmTombow arebut there seems to have been a few issues with supply. However, my favourite pencil elves at [url][https://www.pencils4artists.co.uk/PBSCC ... Init=1/url] appear to have got their supply lines sorted.
It's only done 8,000 miles. Should last 4 years OK. I'll try the spare.Screwdriver wrote: Thu Mar 16, 2023 9:05 pm Just as likely to be worn pins in the lock or a worn key (or both). Visual inspection on key would be a good start.
Try a different key if you have a spare or get a new key cut to try it.
porter_jamie
my 4xv had a slightly worn lock, you had to wiggle the key in the certain way.
What's a 4xv?porter_jamie wrote: Fri Mar 17, 2023 9:46 am my 4xv had a slightly worn lock, you had to wiggle the key in the certain way.
- Has thanked: 6115 times
- Been thanked: 15466 times
1998 Yamaha R1.Yorick wrote: Fri Mar 17, 2023 9:51 amWhat's a 4xv?porter_jamie wrote: Fri Mar 17, 2023 9:46 am my 4xv had a slightly worn lock, you had to wiggle the key in the certain way.
- MrLongbeard
- Has thanked: 777 times
- Been thanked: 3208 times
